Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Jal language help
Jal language help
Old 14th April 2015, 10:09 AM   #1
thimios is offline thimios  Greece
Default Jal language help
I want a big help
The goal is to change the "welcome message" in a software written in Just)Another)Language).
This software is in a Pic18f452, controlling a number of relais,an LCD 2x16,and the Pga 2311A.
This article is publised in Elektor magazine as "High end preamplifier"
Here is athour's website.ben hinrichs - dh3ben
The project is in the "electronics" directory.
Many thanks to rsavas who promised help
Old 14th April 2015, 02:29 PM   #2
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Can you open the hex file of the program with something like notepad? Then search for the string of the current welcome message and replace it, taking care that the new message must have EXACTLY the same length. Then save and transfer to the processor.
Edit: The welcome string is in init_vv. I think the JAL compiler is free from its developer? Then it's just a case of changing the text and re-compile and put in the controller.
Or just email the guy who developed it - it's a 2-min job if you are set up for it, chances are he likes that you build it and would be happy to do it for you!
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 14th April 2015, 03:14 PM   #3
Jan
Hi jan ,i have already downloaded Jal and the sourcecode but do not know the procedur exactly.So i will waiting for someone to guide me step by step.
Thanks for your interesting,i apreceate this!
Old 14th April 2015, 03:43 PM   #4
rsavas is offline rsavas  Canada
right on, Jan has one way to do it to.
since it is ascii and you know the exact string length, do a simple substitution of ascii characters. take a look at your ascii tables.
i think i emailed ben once = no reply?
the compiler is command driven, so you have to get a ms-dos command window going.
change dir to the run directory where the source code resides.
at the prompt
>jal & return 'to get the command line options, so you know the how to insert the {file name} & {options}
"jal" will generate a hex file, if it runs error free. you need a programming plug made up and attached to the processor, so that you can access the mcu programming pins, with your programmer and program the device. that is about it in a nut shell without all the details. btw i have a mplab icd3, i think i used it once and then moved on to atmel xmega. lets see where you end up.
good luck Rick
Old 14th April 2015, 05:20 PM   #5
jan.didden's Avatar
There's a setup file in the .zip which has the command line arguments iirc.
Jan
Old 14th April 2015, 05:47 PM   #6
there is a batch file that you run from the command line
originally,
@ECHO OFF
z:\elektronik\software\jal\jal0459\jal -sz:\elektronik\software\jal\jal0459\lib -ssetup %1 %2 %3 %4 %5 %6 %7 %8 %8 %9 _vv.jal
copy /Y _vv.hex ..\..\..\..\icprog1.05
I changed mine to be
@ECHO OFF
d:\JAL\jal-0.4.60\jal-0.4.60.win32\jal -sd:\JAL\jal-0.4.60\jal-0.4.60.win32\lib -ssetup %1 %2 %3 %4 %5 %6 %7 %8 %8 %9 _vv.jal
so change to where you installed jal on your computer.
Old 14th April 2015, 07:03 PM   #7
Please look here.
Is it nessesary to open all files included to start compile?
Old 14th April 2015, 07:15 PM   #8
that is it!! but
you are not doing what I have written above. use the original compiler first, before you go off and use a new version of the software.
read the source code, it says in "_VV.jal",
-- Thanks to the JAL-Team for this great compiler
-- To be compiled against jal0459
once you have that figured out then go and try out the new version.
Old 14th April 2015, 10:47 PM   #9
carcass is offline carcass  Portugal
As mr. Ben Hinrichs didn't use strings in the source code, but instead the lcd procedure runs each character one at a time, the string PreAmp v1.000 elektor etc... won't be "visible" in the hex file, so, I've tried to assemble it back to pic18F code, but unfortunately can't seem to find the data (I didn't try MPLAB as I do not have it installed though...)
So the easiest way would be indeed to recompile it again as jan and rsavas stated
Old 15th April 2015, 03:29 PM   #10
originally,
@ECHO OFF
@ECHO OFF
Is it possible to run this under winXP?
Where i must change the "welcome message"?
Where i must save files ?
I want more details if it's possible.
Jal language helpHide this!Advertise here!
Universal language scott wurcer The Lounge 4 3rd December 2011 03:36 PM
The relationship between Language and Thought thadman The Lounge 69 10th May 2011 10:22 PM
lyrics-language question Juergen Knoop Music 3 23rd July 2007 12:21 PM
Language Help palesha Solid State 6 25th August 2002 03:51 PM
