Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Jal language help
Jal language help
Old 17th April 2015, 03:58 PM   #21
thimios is offline thimios  Greece
Ok is a working hex!
Thanks rsavas
Some pictures
1&2&4 the development board(Elektor published)
3)a screen capture during procedure
5)the welcome message
6)preamplifier control board(Elektor published)
7)preamplifier power supply
8)preamplifier inp.selector
9)development board & ICD2 clone(Elektor published)
I must report that i.c programmer didn't working good under WinXP
Old 17th April 2015, 04:49 PM   #22
rsavas is offline rsavas  Canada
very good, glad to see it is working correctly.
cheers
Rick
Old 17th April 2015, 04:55 PM   #23
cheers
Rick
Thanks Rick!
Now i have a fish but i don't know the fishing way
Old 17th April 2015, 10:29 PM   #24
so i supply the worm,
funny you mention fishing, we are eating some Perch from Lake Simcoe tonight.
caught this winter ice fishing.
Old 18th April 2015, 06:19 AM   #25
If it isn't big effort for you , some screen schots will be useful to see how this(programming) done
Old 18th April 2015, 04:46 PM   #26
first download & installed the correct compiler version from
JAL compiler - Browse /jal-win32/0.4.60 at SourceForge.net
then i edited the init_vv.jal file(see attached) to change the start up lcd display message string, to what you wanted,
then i edited the batch file (jal.bat)to point to the directory where i installed the jal compiler as so,
@ECHO OFF
c:\sw\jal-0.4.60.win32\jal -sc:\sw\jal-0.4.60.win32\lib -ssetup %1 %2 %3 %4 %5 %6 %7 %8 %8 %9 _vv.jal
then from the dos command line prompt,
Start -> run -> type "cmd" , to get the dos command line prompt app
c:\
i ran the batch file from the directory where the edited source file(s) reside.
c:> cd c:\project\Hi-End_pre-amp\SW\v1.1-copy
c:> .\jal.bat
Old 18th April 2015, 04:52 PM   #27
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
It will be difficult to get some understanding just from screen shots, you need some residual knowledge.
For instance, that a compiler can take a collection of source files (of which init_vv is one) and put them all together in a program and convert the high-level statements (see again init_vv as an example) into a bunch of hex instructions that the processor understands.
You don't need to understand those, but you DO need to know what statements the compiler understands and what the effect is. Luckily, a compiler language is almost readable while a hex file definitely is not!
So if you are serious about this, clean your agenda for the next few weeks and get a reference manual for JAL :-)
And, of course, no compiler or assembler will teach you programming. Programming means you develop some plan of what you want to do, like read in the changes of a rotary encoder for instance, and display the values on an LCD. Then, you consult the compiler manual to see what statements are available (like reading an encoder and displaying numbers) and construct your program in terms of compiler statements. Then the compiler does the rest.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 18th April 2015, 05:03 PM   #28
Thx Jan for helping us out
good documentation is so much help.
now once we have the formalities in order, what is the end goal?
1) just to understand the programming/compiler process?
2) add,modify,fix a bug in the existing code?
Old 18th April 2015, 05:10 PM   #29
jan.didden's Avatar
Hah! Fixing a bug in someone else's program is extremely difficult because you must not only understand the whole language/syntax etc but also must get into the head of whoever wrote the program - so many ways to skin a cat and all that.
Many times it is faster just to write your own program!
And, what the goal is - that's for you to set...
Jan
Old 18th April 2015, 05:24 PM   #30
actually i studied the code thoroughly, it is very well written code. except the rc5 stuff i got a bit lost there. i did not do any rc5 testing either,
i wonder if the rc5 decoder works?
anyone test it out?
i used very little of the jal code when designed my own stereo, but i did switch over to xmega and bascom, so that sort of does a reset in your code.
but you are correct, fixing someone else's code is a challenge.
Jal language helpHide this!Advertise here!
Universal language scott wurcer The Lounge 4 3rd December 2011 03:36 PM
The relationship between Language and Thought thadman The Lounge 69 10th May 2011 10:22 PM
lyrics-language question Juergen Knoop Music 3 23rd July 2007 12:21 PM
Language Help palesha Solid State 6 25th August 2002 03:51 PM
