Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
WinPCD version 1.0 released
Old 21st March 2013, 12:12 AM   #21
dlr is offline dlr  United States
Originally Posted by ra7 View Post
I'm not sure how you'd do that in Holm. Maybe there is an option in the in the export dialog.
It displays correctly in Holm and works perfectly in the excel PCD.
Did you also enable the csv format?
I'll consider making a change for that. However, HOLM has many options for export. I can't easily add handling for the multiple possible export options. White space (tab or spaces) is more often the format used in measurement software in my experience.
In the main Measurements tab, you have an Export button. When you go into the "Export response to file" dialog, use the Text Options tab. Select either the Space or Tabular option in the Column Separator section.
Also, in the Frequency tab, the Export Phase has an Unwrap phase checkbox. Just set those two and you shouldn't have any problems.
Dave
Old 21st March 2013, 12:28 AM   #22
ra7 is offline ra7  United States
Thanks, will give it another try today.
Old 15th May 2013, 12:58 AM   #23
zog666 is offline zog666  Australia
I just found this package and so far I'm very impressed, thanks!
It also saves me having to have excel - until I found WinPCD I had to use my work PC (which has excel installed) to do the crossover modelling.
One strange thing however is that my summed response always gets very jagged in the middle at the crossover point - none of the screenshots of other peoples crossovers seem to have this? I'm using files exported by Room EQ Wizard, but the individual responses look fine. Do I have to smooth them even more? I have tried making the files sparser, different increments of Hz, etc, but I still get "the jaggies" at the crossover point.
The PCD excel spreadsheet exhibits the same behaviour.
example of what I am talking about:
audio project blog http://www.minirig.org.au/
Old 15th May 2013, 02:04 AM   #24
Default May be window used during measurement
I'm glad you like it so far. Since you say that PCD exhibits the same behavior, it's highly likely to have something to do with the data. The jagged response of the individual drivers likely includes rapidly fluctuating localized phase response. This rapidly changing phase of each file as exported from the measurement software may have some error in it.
It may also be that the frequency response that is extended down to 100Hz may be from a window that includes reflections that should not be included, at least for the woofer. If the window is the same for the tweeter, same thing.
I would suggest looking into two areas. Check the window used, the window length may need to be reduced, possibly to 3-3.5 msec maximum. If that is not the issue, smoothing may help.
Please keep me up-to-date with your results.
Dave
Old 15th May 2013, 02:45 AM   #25
follow up:
The measurements from REW have the phase all over the place. Theres something about I need to have a loopback connection to get correct phase, but as I'm using a USB mic I cant do that.
I redid the measurements with Holmimpulse and they look a lot smoother, with a more reasonable looking phase.
Old 15th May 2013, 02:53 AM   #26
Thanks for the fast response! And you were correct, messed up phase from REW was the reason.
Below are the measurements redone with Holmimpulse.. the absolute dB magnitude is off a bit, but relative to each other it now looks OK (slightly different crossover selected):
Old 15th May 2013, 03:36 AM   #27
Definitely an improvement. I'm glad you found a fix for the problem.
Dave
WinPCD version 1.0 releasedHide this!Advertise here!
Active Crossover Designer version 2 released CharlieLaub Software Tools 1 12th November 2012 09:08 PM
New version of Basta! released. Svante Multi-Way 18 26th December 2007 08:03 PM
Released from my personal collection... planet10 Swap Meet 0 23rd January 2004 07:39 AM
AsioXO version 1.2 released Henckel Digital Source 0 23rd December 2003 09:39 AM
