LTSpice tube models - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 24th October 2013, 09:11 PM   #21
jazbo8's Avatar
You need to convert the model so TINA can use it, just a few syntax changes. IIRC, something to do with the uramp function.
Old 25th October 2013, 02:47 AM   #22
cogsncogs's Avatar
Originally Posted by coffin View Post
Thanks a lot!
But when used the macro wizard to import EC86.mod, TINA-TI told me line 11 "V" is invalid function......
No conversion needed if you use the .inc file. In a text editor, save the .inc file as a .cir file. File -> Import -> PSpice netlist, load .cir file you saved -> compile.
Tools-> New Macro Wizard, blah, blah.
Old 25th October 2013, 03:55 PM   #23
coffin is offline coffin  Taiwan
coffin's Avatar
Hi
Yes! It works!
Thank you very much!
Still looking for the model for EC88 and EC8010.....please help.
cheers
Coffin
Ignorance and self-centered are the epidemics of human.
Old 25th October 2013, 05:13 PM   #24
jazbo8's Avatar
Hi
Yes! It works!
cheers
Coffin
You can make your own with Dmitry's model paint tool, very easy to use and accurate.
Old 25th October 2013, 09:15 PM   #25
cogsncogs's Avatar
Hi
I made these using Andrei's Curve Captor.
Grid current is NOT modeled.
Code:
* EC88_RT UHF triode PSpice model
* Modified Koren model (8 parameters) mean fit error 0.223476mA
* Traced by Wayne Clay on 09/09/2007 using Curve Captor v0.9.1
* from La RadioTechnque data sheet
.subckt EC88_RT  P G K
    Gp  P K  VALUE=
+ {(0.1257435776m)*limit(V(P,K)*log(1.0+(-0.1054262489)+exp((2.84824757)+
+ (2.84824757)*((71.52634978)+(-3035.182931m)*V(G,K))*V(G,K)/sqrt((66.04621849)**2+
+ (V(P,K)-(31.49056194))**2)))/(2.84824757),0.0,1.0e16)**(1.088580283)}
    Cgk G K 4.5p ; 0.7p added
    Cpk P K 0.255p ; 0.2p added
    Cgp G P 2.2p ; 1.0p added
  Rpk P K 1G ; to avoid floating nodes
  d3  G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends EC88_RT
Code:
* EC8010 PSpice model
* Modified Koren model (8 parameters): mean fit error 0.426794mA
* Traced by Wayne Clay on 10/24/2013 using Curve Captor v0.9.1
* from Telefunken data sheet
.subckt EC8010  P G K
    Gp  P K  VALUE=
+ {(0.238786713m)*limit(V(P,K)*log(1.0+(-0.05597274459)+exp((4.243631263)+
+ (4.243631263)*((59.60099868)+(-2994.534169m)*V(G,K))*V(G,K)/sqrt((52.4537805)**2+
+ (V(P,K)-(6.756930625))**2)))/(4.243631263),0.0,1.0e16)**(1.118056622)}
  Cgp G P 2.5p ; 1p added
  Cgk G K 7.5p ; 1p added
  Cpk P K 0.3p ; 0.2p added
  d3  G K dx1
.ends EC8010
Old 25th October 2013, 09:26 PM   #26
cogsncogs's Avatar
In the above models, the diodes are merely there to help in convergence. If you prefer not to have or need them, just comment (*) them out.
Old 26th October 2013, 06:57 AM   #27
coffin's Avatar
Thanks for great help!
Old 26th October 2013, 07:04 AM   #28
coffin's Avatar
Gee! This looks great! Thank you for sharing!
GM70 and Other LTSpice Tube Models kevinkr Tubes / Valves 20 31st August 2012 11:45 AM
Symbol for tube diode in LTspice JoeAlders Software Tools 7 29th April 2012 03:49 PM
LtSpice - Russian tube models Svein_B Tubes / Valves 11 5th May 2010 03:55 AM
Ltspice and Valve models Melon Head Software Tools 3 18th October 2009 09:35 AM
Need help with tube models in LTSpice Bitrex Tubes / Valves 5 6th August 2009 08:28 PM
Copyright 1999-2017 diyAudio
