LTSpice tube models
tubemodel_3.01_win.zip
EF184 would be 6EJ7 in the above zip.
EC900/6HA5
* 6HA5 LTSpice model
* Koren model (5 parameters): mean fit error 1.27016mA
* Traced by Wayne Clay on 9/6/07 using Curve Captor v0.9
* from GE datasheet
.subckt 6HA5 P G K
Bp P K I=
+ (0.0007088605362m)*uramp(V(P,K)*ln(1.0+exp((0.01050076569)+
+ (0.01050076569)*(16410.47684)*V(G,K)/sqrt((7.516756983k)+
+ (V(P,K))**2)))/(0.01050076569))**(1.177167506)
Cgp G P 0.56p ; 0.2p added
Cgk G K 5p ; 0.7p added
Cpk P K 3.1p ; 0.2p added
.ends 6HA5
6HM5
Code:
* 6HM5_k8 LTSpice model
.subckt 6HM5_k8  P G K
    Bp  P K  I=(0.001154846006m)*uramp(V(P,K)*ln(1.0+(-0.0008415623491)+exp((0.05049252985)+(0.05049252985)*((5446.000628)+(178663.8165m)*V(G,K))*V(G,K)/sqrt((-0.2140185688)**2+(V(P,K)-(-162.56846))**2)))/(0.05049252985))**(1.356125726)
.ends 6HM5_k8
Code:
* 6HM5 LTSpice model
* Koren model (5 parameters): mean fit error 1.20978mA
* Traced by Wayne Clay on 9/9-07 using Curve Captor v0.9
* from GE datasheet
.subckt 6HM5-k5  P G K
    Bp  P K  I=
+ (0.0005835219273m)*uramp(V(P,K)*ln(1.0+exp((0.005618954395)+
+ (0.005618954395)*(31322.45425)*V(G,K)/sqrt((8.885069314k)+
+ (V(P,K))**2)))/(0.005618954395))**(1.124019828)
  Cgp G P 0.54p ; 0.2p added
  Cgk G K 5.2p ; 0.7p added
  Cpk P K 3.2p ; 0.2p added
.ends 6HM5-k5
I don't have any good ones for those tubes. Here's 6BE6 and 6CS6 models that use an op-amp symbol. To use 3f4 in LTSpice you may have to change ^ to **.
Code:
*Vacuum Tube pentagrid  (sharp cutoff)
.SUBCKT X6CS6close G 3 S K A
*model written to use op-amp symbol +in=g1,-in=g3, +supply=g2g4, -supply=kg5, out=plate
*work in progress, not final
* Calculate contribution to cathode current
*the number at the right end determines sharpness of knee
Bat    at  0    V=0.636*ATAN(V(A,K)/8)
*the URAMP(V(S,K)/# mostly determines peak plate current, grid line spacing nearly constant
*the number at the right end determines slope of grid lines (plate resistance)
Bgs    gs  0    V=URAMP(V(S,K)*1.6164+V(G,K)*24.75+V(A,K)/9000)
Bgss    gss  0    V=URAMP(V(S,K)*0.0005+V(3,K)*0.0075+V(A,K)/9000)
*the exponent sets the linearity of grid line spacing, and big impact on peak plate currrent
Bgs2    gs2 0    V=V(gs)^1.5
Bgs3    gs3 0    V=V(gss)^1.5
Bcath    cc  0    V=V(gs2)*V(at)
Ban          an  0        V=V(gs2)*V(at)*(V(gs3))
* Calculate anode current, grid line spacing adjust and peak plate current
Ba    A   K    I=0.345E-3*V(an)
* Calculate screen current
Bscrn    sc  0    V=V(gs2)*(1.0-V(at))
Bs    S   K    I=(URAMP(0.64E-3*V(sc)-(1.45E-3*(V(an)))))*0.29*(V(at))
* Grid current (approximation - does not model low va/vs)
Bg    G   K    I=(URAMP(V(G,K)+1)^1.5)*50E-6
* Capacitances
Cg1    G    K    5.5p
Cak    A    K    7.5p
Cg3          3              S              7p
Cg1g3       G            3              0.36p
Cg1a    G    A    0.07p
.ENDS X6CS6close
Code:
*Vacuum Tube pentagrid (g3 remote cutoff)
.SUBCKT X6BE6close G 3 S K A
Bgss    gss  0    V=URAMP(V(S,K)*0.0005+V(3,K)*0.0045+V(A,K)/9000)
Bgs3    gs3 0    V=V(gss)^2.7
Ba    A   K    I=0.345E-2*V(an)
Bs    S   K    I=(URAMP(2.34E-4*V(sc)-(0.95E-2*(V(an)))))*0.29*(V(at))
* Capacitances
Cg1    G    K    3p
Cak    A    K    8p
Cg3          3              S              7p
Cg1g3       G            3              0.15p
Cg1a    G    A    0.1p
.ENDS X6BE6close
Hi Osvaldo, try this in LTSpice. It has the 6HM5 model I posted in this thread. When you use the model be sure the name of the subckt matches the name/value of the component and the inc file you place on the schematic.
Wayne ;)
  • 407A-B-pre.zip
Ex-Moderator
Joined 2011
Hi again. I found that this guy has made his own tube models using a point to point curve digitalizing, and has a great job and explained it. But I could't find why in some instances he used a "dummy resistor" in the text and how to estimate or calculate it and for what did he use it. Can somebody explain me this?
Best regards.
You can send him a private message to see if he would answer your question. But looking at the model, I think the dummy resistors are used for either source or load impedance, most likely for SPICE calculation convergence purpose.
Ex-Moderator
Joined 2011
Did anyone get anything in the tubemodel_3.01_win.zip to work in LTSpice? I tried the 6ej7 pentode connection but it did not work.
Some don't work but most do, is my experience. I don't use LTSpice but SIMetrix, here is the Ia vs Vs plot for the 6EJ7 using Ayumi's model, matches up well with the datasheet:
