Spice simulation - Page 83 - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 13th February 2009, 09:09 PM   #821
Thanks OS good work, do not understand why this amplitude ({sprt(2)})?
Window in which used fft ? I have an article in portuguese it has windows for measuring instruments in fft, I put only the table
Note:Leakage, behavior is not predictable where the signal is not zero(Ex: pink noise) this"leakage"just damaging the samples following.
Table:
Old 14th February 2009, 12:05 AM   #822
ostripper's Avatar
Not my work,man. Andy c. (the LT master) is the creator..
Perhaps he can explain sqrt (2) and the different
type windows you have presented. Curious ???
OS
Old 14th February 2009, 12:27 AM   #823
andy_c is offline andy_c  United States
Banned
Oh, that sine_gen.zip is just something I threw together real quick to help OS troubleshoot a problem he was having with a high FFT residual a while back. It wasn't meant as some kind of model for how to do things in the most general way. I've attached a new one in which the frequency and number of FFT points are parameters, which makes it more general. The one OS posted works best only at 1 kHz.
The idea is to have the max time step be one period divided by (num_FFT_points - 1). I've also set it up to do an automatic THD calculation without having to do an FFT from the graphs. Run the sim and do a view, SPICE error log to see the zero percent distortion of the source in text form.
When doing an FFT from the graph, LTspice chooses 0 dB as 1 VRMS. Since 1 VRMS is sqrt(2) Volts peak, that's what I chose for the amplitude of the source. So when you do the FFT from the graph, the source will be normalized to 0 dB.
Edit: OS, I think you put the old sine_gen.zip on your site? I hadn't meant it for reference, just a quick fix. The one attached to this post is more general.
File Type: zip sine_gen.zip (468 Bytes, 172 views)
Old 14th February 2009, 02:53 AM   #824
ostripper's Avatar
thanks, andy, that is way cool..(attached) the old one still is WAY
better than a standard source , but this one takes the cake..
Os
Old 14th February 2009, 03:47 AM   #825
ostripper's Avatar
I was just wondering, after simulating my new "baby".., could
one comment out a verbose distortion log ?? (H2 - H7)
looking at the data , it seems as the distortion readout sums
the fourier phases. could comments be added to give H2 , 3,5
and 7 , too ??
I can see my h2 and 3 here, (the 2 e-05's)
Fourier components of V(c)
DC component:0.041085
Harmonic Frequency Fourier Normalized Phase Normalized
Number [Hz] Component Component [degree] Phase [deg]
1 1.000e+03 8.060e+00 1.000e+00 -0.40 0.00
2 2.000e+03 1.979e-05 2.455e-06 -101.51 -101.11
3 3.000e+03 1.991e-05 2.470e-06 -103.13 -102.74
4 4.000e+03 6.748e-06 8.372e-07 157.60 157.99
5 5.000e+03 3.251e-06 4.033e-07 -122.74 -122.34
6 6.000e+03 5.045e-06 6.260e-07 165.93 166.33
7 7.000e+03 3.725e-06 4.621e-07 88.48 88.87
8 8.000e+03 3.740e-06 4.641e-07 169.05 169.45
9 9.000e+03 5.324e-06 6.606e-07 84.85 85.25
Total Harmonic Distortion: 0.000377%
OS
Old 14th February 2009, 03:50 AM   #826
Thanks Andy
I wonder if it is possible obtain separate graphics of harmonics(2nd, 3rd, ...)Mag versus spectrum (20 and 20KHz)
This web , (4 fig) author used EWB:
http://www.geocities.com/ResearchTri...cheminf1e.html
I found these calculations that web, do not know if this related, with get graphics separated from the harmonics ?
http://www.allaboutcircuits.com/vol_2/chpt_7/2.html
Old 15th February 2009, 04:59 PM   #827
Banned
Originally posted by ostripper
I was just wondering, after simulating my new "baby".., could one comment out a verbose distortion log ?? (H2 - H7)
Hmm, I'm not sure what you mean by that. Could you explain a bit more? The number of harmonics defaults to 9 if not specified. You can specify the number of harmonics you want displayed and included in the calculation. See the docs of ".FOUR" for how to do this.
looking at the data , it seems as the distortion readout sums the fourier phases. could comments be added to give H2 , 3,5 and 7 , too ??
The Fourier phases don't play any part in the THD calculation. THD is calculated by taking the square root of the sum of the squares of the distortion component amplitudes, dividing that by the amplitude of the fundamental, and multiplying by 100 to get percent.
I might be misinterpreting your question though. I don't know of any way to change the distortion display in the error log other than specifying the number of harmonics that's included.
Old 15th February 2009, 05:07 PM   #828
Banned
I don't know of any automated way to do this in LTspice. If you want to simulate distortion over many frequencies, you can change this statement:
.param freq 1k
to:
.step param freq (options for .step command here)
See the documentation for .step for how to specify start value, stop value, increment, etc. You can do logarithmic steps, step in a list, etc. You'll want to change the stop time in the simulation to something like {20/freq} to give 20 cycles no matter what freq is.
Then the SPICE error log will have a table of harmonics for each frequency. I have plotted these in the past by pasting them into Excel. I don't know of any clean way to do this.
Old 15th February 2009, 08:30 PM   #829
teodorom's Avatar
There is an automated way to do all that.
Look in the LTSpice forum, libraries, all that, and you will find that way.
Using a little Perl program the simulation is run as many times you need then the results are collected so that they can be shown.
Teodoro
Old 15th February 2009, 10:16 PM   #830
Banned
I noticed that a while back, but it looks like it only plots THD vs. a parameter. If I understood correctly, Rafael was asking about individual harmonics (see his links).
Need help with Spice simulation overmind Everything Else 4 23rd December 2002 04:58 PM
Copyright 1999-2017 diyAudio
