im buildar a bass guitar cab for my friend who currently has an ampeg BXT-115HL4. would it be benefical to have a full range( up to 9k) type bass guitar cab using a phl 5200 15inch woofer and selenium 1 inch compression driver? vs his current cab which i think has an eminance omega pro-15a 15inch woofer and some little eliptical or exponential flare horn tweeter crossed in at 6k. so i have a couple compression drivers and a couple horns in mind. one compression driver is good from 500hz to 9k and the other is good from 2k to 20kand i wanted to know what you guys think of any combination of these horns and compression drivers. i already have the phl on the way. links:
phl woofer
http://www.phlaudio.com/datasheets/38_pdf/5050_5200.pdf
option one selenium phenolic compression driver
http://www.partsexpress.com/pdf/264-202.pdf
option 2 selenium titanium compression driver
http://www.partsexpress.com/pdf/264-235.pdf
option one horn
http://www.partsexpress.com/pe/pshowdetl.cfm?&PartNumber=270-099&DID=7
option two horn
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=270-302
any advice, suggestions, or questions welcome.
thanks
koa
phl woofer
option one horn
option two horn
thanks
koa
If you fit a tweeter, make sure you fit a switch on it - many bass players prefer the sound without the tweeter, and such cabs commonly have switches on them. But most bass cabs probably don't include tweeters at all.
Tell your friend to check out Avatar's Speaker cabinet. I own a couple of his guitar cabinets and they are very nice quality. The bass cabinets that he sells has a tweeter with crossover and volume control and they are really inexpensive.
Avatar Bass Cabinet.
Maybe you could try to build a Bill Fitzmaurice cab, like the Omni15, with an Eminence Kappalite 3015LF, MR8A, ASD1001 and Selenium horn.
Mine is just finished (today !) :
Amazing !
Amazing !
thanks for the suggestions. i definitely will put on a switch for the tweeter. gotta think about horn loading the woofer. i guess the switch would turn off the tweeter and bypass the lowpass on the woofer. i haven't decided whether im going to lowpass the woofer or run it full range and use a higher shallower crossover on the tweeter. that would make the switching slightly easier. most likely going with a bass reflex just for cosmetics and ease of construction. the two 15 box looked cool but a harder to transport. the portability was of moderate to high concern thus the single 15.
do you guys think i should go with the phenolic compression driver and keep the dispersion wide on the woofer but lose above 9k or should i go with the titanium compression driver and compromise dispersion on the woofer using it up to 1.5-2k and the tweeter from 2k up to 20k?
KOA said:thanks for the suggestions. i definitely will put on a switch for the tweeter. gotta think about horn loading the woofer. i guess the switch would turn off the tweeter and bypass the lowpass on the woofer. i haven't decided whether im going to lowpass the woofer or run it full range and use a higher shallower crossover on the tweeter. that would make the switching slightly easier. most likely going with a bass reflex just for cosmetics and ease of construction. the two 15 box looked cool but a harder to transport. the portability was of moderate to high concern thus the single 15.
You wouldn't normally bother low-passing to the bass unit, just a high-pass to the tweeter - so it only needs a simple single pole switch.
It's rare to have horn loading on a bass guitar cab, they are usually just reflex - size and weight are usually pretty important!.
yeah i just got the driver today so we are going to take it down to genesis advanced technologies and get it tested so we can make the appropriate crossover.
KOA said:yeah i just got the driver today so we are going to take it down to genesis advanced technologies and get it tested so we can make the appropriate crossover.
You don't think you're over complicating this?, it's NOT a HiFi speaker, it's for a musical instrument - you're not looking to get a flat frequency response - chuck it in a box and play a bass through it and see how it sounds!.
Personally, I wouldn't use a compression driver. I'd use soft domes. Those compression drivers will be way overkill @ 107db sensitivity.
I'd probably forget the tweeter alltogether, and use a 6" mid in a standard 2-way configuration. Chances are you can get a decent mid up to 5 or 6khz, which should be sufficient.
If I had to use a tweet, I'd look at a Morel MDT37 (madisound) or something like that. Maybe two Audax TW025's.
And if you use a tweet, put in a L-pad with an on/off switch.
I'd probably go with a Kappalite 3015LF also. But I see you've already bought your woofer.
P.
P.
pneuma said:I'd probably forget the tweeter alltogether, and use a 6" mid in a standard 2-way configuration. Chances are you can get a decent mid up to 5 or 6khz, which should be sufficient.
P.
I'm helping a friend with a bass cab and amp and that's the route we're taking. No point in anything about about 9Khz, and the 6" should cross over better to a 15". We'll probably have to use two 6" mids to match the sensitivity of a single 15 though.
The Eminence LA6-CBMR is ~ 98dB, takes 150w RMS, and is sealed/closed back. You don't have to make a separate cab for it. Weighs about 7lbs. Should be good to ~ 5khz.
P.
If adding a tweeter to a 15" the 4"x10":
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=280-050
Is probably perfectly adequate if attenuated / protected (aerospace bulb).
🙂sreten.
🙂sreten.
that horn looks very interesting. and a good deal. we might forgo the testing at genesis. what type of attenuator would i use?
You need a crossover followed by an L-pad.
Not at 800Hz, I'd go higher, a question of blending with the bass driver.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=260-268
Note you rotate the L-pad so 0 is your "normal" level.
I would use a 16 ohm L-pad ( do not worry about the mismatch)
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=260-254
There are other ways of doing it :
Capacitor followed by L-pad followed by 2nd order LC filter then driver.
Is probably the best way, 2nd order at say 1.4kHz, vary input capacitor to suit.
🙂/sreten.
P..S. if you go for it, get one of these now : http://www.partsexpress.com/pe/showdetl.cfm?Partnumber=280-051
🙂/sreten.
yea i was thinking i'd get a couple of those diaphrams just for testing and fun, and the lpad sounds like a good idea also.
I bought a couple of these to fill out the top end with my old JBL K-145s. Haven't done it yet, but I've used these before (non-neo versions) and they are great little speakers. Anyone else tried these in Bass cabs?
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=290-020
Here's the non-neo version:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=290-015
hi Snikpout - do you think Omni 15's bass section (and perhaps the whole cabinet) would be good for home stereo?
Freddy
Freddy
freddi said:hi Snikpout - do you think Omni 15's bass section (and perhaps the whole cabinet) would be good for home stereo?
Most probably not?, musical instrument speakers and HiFi speakers are completely different items, with completely different purposes.
- Live Sound
- Instruments and Amps
- any electric bass players? im building a bass guitar cab
