Searching the better DAC testing all
I have opened a new webpage about DAC chips test.
The test will be with 2 different output stage: hybrid vacuum tube or simple transformers.
Each DAC chip will be tested in the best condition depending to the characteristics.
- some will have a passive I/V and other an active I/V
- when possible will be used a modo configuration
Here the link with the first webpage:
http://www.audiodesignguide.com/DAC_final/DacFinal.html
Any contributtion is welcome!
2x15 ohm is for LP-filtering I guess, but 2x220? Are you using proper decoupling before/after regulator, like 0.1µ polypropylene?
Really interesting test by the way, are you intending to test the OP275 with other popular audio OPs like OPA134 etc? Is -80dB the limit of your equipment?
Keep it up :D
edit: typo
Well the shunt seems ok I guess, I've never used it myself. Though I don't quite follow why you've settled with 100ohm (2x200 for load relaxation) after reading the white paper...
I'm myself building a DAC with ad1896, pcm1798 and opa2134 as IV. I'll benchmark that one with my NAD 521BEE (older DAC, NE5534) and it would be really interesting if we conclude something similar :clown:
I'm using cheap 2x3000µF for the supply with 7812s for the OPs and lm1117 for all lower voltages. After each regulator I make shure to use low impedance caps, hoping that would keep enoguh decpoupling in pair with 0.1µ polyprop and 0.1µ ceramic IC-bypass.
Keep it up! :smash:
shunt ripple
I have simulated the shunt with:
vp 20 21 dc 0 ac 15 sin(0 15 50)
d1 0 20 D1N5406
d2 0 21 D1N5406
d3 20 19 D1N5406
d4 21 19 D1N5406
c1 19 0 4700uF
c2 19 0 4700uF
r0 19 22 7.5
c3 22 0 4700uF
c4 22 0 4700uF
r1 22 24 110
r3 24 23 1500
r4 23 0 1500
c5 24 0 22uf
x1 23 0 24 TL431
rl 24 0 100
TL431 model
I use Winspice3 and this TL431 model:
* REFERENCE
* | ANODE
* | | CATHODE
.SUBCKT TL431 1 2 3
V1 6 7 DC 1.4V
I1 2 4 1E-3
R1 1 2 1.2E6
R2 4 2 RMOD 2.495E3
R3 5 7 .2
D1 3 6 DMOD1
D2 2 3 DMOD1
D3 2 7 DMOD2
E1 5 2 POLY(2) (4,2) (1,2) 0 710 -710
.MODEL RMOD RES (TC1=1.4E-5 TC2=-1E-6)
.MODEL DMOD1 D (RS=.3)
.MODEL DMOD2 D (RS=1E-6)
.ENDS
