Are These Wattage Ratings Right?
So aside from the output network are most of them the right size (or in toher words as small as they can safely be) because i wana use as close to the right value as possable but i don't wana go too low.
The 4R7 output resistor only needs to be big if you are going to run full power 20 kHz sinewaves on the bench, or maybe for some non-audio application. For normal music a 1 watt should be just fine, use carbon not wirewound which are sometimes inductive and would therefore defeat the purpose.
GP.
