Are These Wattage Ratings Right?
The 4R7 output resistor only needs to be big if you are going to run full power 20 kHz sinewaves on the bench, or maybe for some non-audio application. For normal music a 1 watt should be just fine, use carbon not wirewound which are sometimes inductive and would therefore defeat the purpose.
GP.
