Hi !
Read error on CD onkyo DX 706.
When it was new it was "superb".
Now the out relay clicks on and off extremely often, when a new cd is inserted.
Beside the big SONY IC to the left there is a trim pot that says gain (actually 2 trim pots)
when turning this a little bit clockwise (19 hours to 21) it works again..
But what gain !!! Laser output or ampl..... ??
Where is the service manual to obtain and read about this..*.pdf
Also the mod for this CD-player is of intrest, at other subject in this area !
Lens is looking 100 % new not a mark on it .
I dropped you an email about the manual.
For modifications start here:
http://www.diyaudio.com/forums/showthread.php?postid=45821#post45821
and
http://www.diyaudio.com/forums/showthread.php?postid=115350#post115350
Nicke
and
Nicke
Spindle motor
Hi to all,
I have a heavily modified DX 706. I was experiencing more and more read problems, until I got tired and oiled the spindle motor. Use a VERY light oil, say like for a fine sowing machine, and use very little. There is a hole at the bottom of the motor, so put a minor drop there to get into the bottom bushing. Results? Mirraculuos!
David
Hi to all,
David
I have also same problems with laser. And now the cd don´t rotate at all, what might be the broblem? Maybe it possible to replace a laser or some par of the mechanism.
Looking for service-manual also 🙂
thanks
thanks
Hi, the outputrelais of my DX 706 also clicked all the time around 3 - 10 minutes after turn on. I found out what the problem is (in my case)...anybody interested about the info?
Chris
Chris
Re: Spindle motor
Hi David,
You say at the bottom. did you take out the motor from the player to access it (the hole), or how do you access it?
Jennice
David Nessim said:Hi to all,
David
Hi David,
Jennice
since i have a DX-706, i am interested. what was the problem?
mlloyd1
mlloyd1
sinus said:Hi, the outputrelais of my DX 706 also clicked all the time around 3 - 10 minutes after turn on. I found out what the problem is (in my case)...anybody interested about the info?
Chris
OK, i try to explain with my baaaad english:
to analyse the problem i haul out the mecanic and pose it beside of the player without deconnecting the electronic.
look
when i turned on the player, i observed that the linear tracking motor started to move left-right with an amplitude of 2-3 mm and and frequence of arround 1Hz. the amplitude of the movement started small and becomes more and more, till the lense couldnt more balance this movmement. when this is the cas, the relais cut off the music, the laser goes wild left-right till he refound the position to continu playing the music, till the next time he loos the balance...
look again
after trying several things, i found out that a small turn of this variable resistor, beside of the power unit, stopped the movement and the problem. Since i do not have the circuit diagramm, i am not really know what i did 🙄 but i think it is to control the voltage regulation.
look
look again
The spindle motor is most certainly your problem as mentioned above.
Avoid the temptation to turn the pots without manual.
The oil might work, never tried.
Onkyo doesn’t supply the original motor anymore but a replacement should be available.
The number would be RF-310T-11400
The table height should be adjusted between 19,3-19,4mm.
The screw holes to fit the new motor don’t match so you’ll have to drill new ones.
That’s about all I know about the DX706.
/Hugo
/Hugo
hugo & sinus:
thanks! that's what i needed to know.
hugo: did you give the part number for the replacement motor or the original motor? I don't have the schematic and parts list handy at the moment. And do you recall the approximate cost?
thanks again,
mlloyd1
thanks again,
mlloyd1
thanks hugo!
you guys are great!
they give absolutely NO info on the spindle motor in the service manual.
the motor and bracket are grouped as a single assembly with an onkyo part number.
mlloyd1
you guys are great!
mlloyd1
Hi, again. have anybody the service manual for this player in a scaned version and can be so nice to share it 🙄? so i can know what i did with the pot...
Chris
Chris
sinus said:OK, i try to explain with my baaaad english:
look
look again
what regulated that variable resistor ??
- Digital Source
- Onkyo CD DX706
