Hello,
Since there is no Amplifiers/Pre-amps forum, and the attenuator will be used with my chipamp, I am posting this here 🙂
Attached is the principal schematic of my relay based attenuator.
I have drawn only 4 relays i.o. the 13 relays needed, but that is because the cad tool's interface was
I want relays i.o. the normal switch most people use for 2 reasons:
- being lazy I need a remote.
This is how it is supposed to work:
There are 3 relays in the diagram connected to the multi-tap transformer, each of these relays is connected to 2 taps on the transformer. By activating one of these 3 relays 2 taps are connected to the 4th relays. This 4th relay is used for selecting either of these 2 'active' taps.
The relays are activated by the 74595 IC (through a driver not shown on the schematic)
The 595 can be controlled using only 3 wires, and by 'daisy chaining' the 595's a sufficient number of outputs is available.
Using opto-couplers the 595's are isolated electrically from the microcontroller board, and only when the volume is changing there is digital activity.
As a result there should be almost no spikes or other nasty things near the analog signals.
Per channel I would need a single board, using the daisychaining feature there is no real limit to the number of channels or taps on the transformers (for me it would be 2 channels and 24 taps transformers).
Does all this look like a project that could result in something good?
I can't find any flaws, but that probably only indicates that I'm not searching hard enough for them 🙂
Thanks for your input,
Peter
Peter
I'm working on the same thing, as you may have seen here: http://www.diyaudio.com/forums/showthread.php?s=&threadid=43067squadra said:Attached is the principal schematic of my relay based attenuator.
I have drawn only 4 relays i.o. the 13 relays needed, but that is because the cad tool's interface was& 😡.
But I use resistors (and six relays) instead of a transformer.
That way the signal will pass through two relays - some will say that's very bad 😉This is how it is supposed to work:
I built a similar board a couple of months ago. You can see a bad photo here: http://stiftsbogtrykkeriet.dk/~mcs/SowVol2.jpg (the one at the bottom). I used an Allegro chip instead of the 595s. That way you can get 32 outputs with relay drivers using one chip instead of 8. The board has drivers for two channels (64 relays) and 16 aditional relays using the 595 and ULN chips on the right.The relays are activated by the 74595 IC (through a driver not shown on the schematic)
Why? The clock signal will be off (i guess) when you are not changing positions. So I don't see what the optocouplers will achieve?Using opto-couplers the 595's are isolated electrically from the microcontroller board, and only when the volume is changing there is digital activity.
Best regards,
Mikkel C. Simonsen
Why not just use a volume control chip like the PGA2311?
256 steps, 0.5dB/step, SNR of -114dB (IIRC), simple SPI interface to the micro, which can be daisy-chained.
I'm putting 3 of them in my 6-ch home theatre amp.
I hope you mean the 2310?TwoSpoons said:Why not just use a volume control chip like the PGA2311?
The reason I don't like the 2310 a lot, is that you need a buffer on the input (if you read the datasheet), you also get an op. amp. on the output. That's two op. amps. that are not required in a transformer/resistor attenuator. You also get more distortion from the CMOS switches in the chip than you get from relays.
The attenuators I make can be made in any impedance, any number of steps (I think 64 is more than enough) and they can handle large signal swings without problems.
Best regards,
Mikkel C. Simonsen
Re: Re: relay based attenuator
That's cool, but I would like to use the transformers because they apparently have higher dynamics on low volumes.
With my solution there is no step where 2 relais need to switch their state.
Your site looks nice, btw.
Too bad you didn't use a PIC, that could have made it easier for me 🙂
I'm not going to try to solder that chip on a pcb 🙂
The 595 & driver ic's are very cheap and I can get them in the shop-around-the-corner.
The clock on the digital board isn't stopped, and this way there is a very high degree of separation between analog and digital boards. Well, that's my aim anyway 🙂
Peter
Some people can even hear differences in the direction a cable is connected in, even when an audio signal is alternating in it's nature 🙂
That is true, and exactly why I will use the optocouplers 🙂
Best regards,
Mikkel C. Simonsen
Peter
Because I wanted to check if these transformer based attenuators sound better as some people claim, and it is a nice, fairly easy project.
Peter
I built a relay attenuator for a headphone project and it was very fun. I will just share what I learned from that project. The design works great and functions as a wonderful attenuator but man, it is noisy. If I were to implement the design again (and I might), here's what I would do:
1) Use relays with an electrostatic shield. The relays I used couple a lot of noise into the signal.
2) Use low-noise resistors. Because my design is a series attenuator, with 16 resistors in the signal path, the resistor noise adds up easily.
3) Use a regulated power supply. The amount of current required to drive the relays and electronics turned out to be quite significant. I initially had used a simple zener and pass transistor regulator, but that wasn't enough regulation and it overheated anyway.
Don't listen to anyone who says you can't drive a relay with a '595. I drive the relay straight off a '595 without any problem.
I do mean the 2311.
The THD+N is quoted as 0.0002% at 1khz. Thats going to be completely swamped by the distortion in the LM4780.
I have an input buffer anyway - INA163 - because I'm doing balanced inputs to try to kill the hum loops that inevitably form when connecting several pieces of equipment together.
Good luck with the relays - make sure you pick signal relays, as the power relays require a decent 'wetting' current to keep the contacts clean.
A trafo with less than 0.0002% distortion is going to be a costly beastie, silicon is much cheaper and I'm on a budget 😉.
Edit: Just noticed something - the input impedance seen by your source is going to change according to which tap you pick. Is this OK for you?
Re: Re: Re: relay based attenuator
I haven't had a "shop-around-the-corner" for 10 years anyway...
Best regards,
Mikkel C. Simonsen
You can get them in a DIL version as well 😉squadra said:I'm not going to try to solder that chip on a pcb 🙂
Best regards,
Mikkel C. Simonsen
I have made a small testboard with different relays. I have had no noise problems at all with those (and I don't think they have shields).jwb said:1) Use relays with an electrostatic shield. The relays I used couple a lot of noise into the signal.
I have 6 resistors max. so the problem should be smaller.2) Use low-noise resistors. Because my design is a series attenuator, with 16 resistors in the signal path, the resistor noise adds up easily.
I always use an 7805 - I have a lot of them 🙂3) Use a regulated power supply. The amount of current required to drive the relays and electronics turned out to be quite significant. I initially had used a simple zener and pass transistor regulator, but that wasn't enough regulation and it overheated anyway.
Depends a lot on the type of relay. A common type like the Omron G5V needs about 100mA as far as I remember...Don't listen to anyone who says you can't drive a relay with a '595. I drive the relay straight off a '595 without any problem.
Why not use the 2310 with the added headroom and (i assume) lower real-life distortion?TwoSpoons said:I do mean the 2311.
That distortion is probably not the worst-case distortion...The THD+N is quoted as 0.0002% at 1khz. Thats going to be completely swamped by the distortion in the LM4780.
But transformer distortion may sound a lot nicer than silicon distortion 😀A trafo with less than 0.0002% distortion is going to be a costly beastie, silicon is much cheaper and I'm on a budget 😉.
Who are you talking to here?Edit: Just noticed something - the input impedance seen by your source is going to change according to which tap you pick. Is this OK for you?
Best regards,
Mikkel C. Simonsen
jwb said:I built a relay attenuator for a headphone project and it was very fun. I will just share what I learned from that project. The design works great and functions as a wonderful attenuator but man, it is noisy. If I were to implement the design again (and I might), here's what I would do:
Build another version, it is fun and also nice to discuss 🙂
1+2: How much noise is generated by the resistors, and how much by the relais?
3: There will be a regulated power supply, probably using a simple 7805.
BTW, I'm not going to skip the drivers, they are cheap and it could be a problem if i have a pcb created and the current required is too high for the 595's.
Wouldn't the isolation provided by a transformer be very useful for that?TwoSpoons said:I have an input buffer anyway - INA163 - because I'm doing balanced inputs to try to kill the hum loops that inevitably form when connecting several pieces of equipment together.
The relay I have in mind is Zettler's ZA832, a small gold plated relay.
Over here they are about 3 euro each (and cheaper in larger numbers)
The input impedance of the chip amp is about 100k, if the transformer is ideal then the impedance as seen by the source is 100k or higher.
My source has buffered outputs, but even without buffer I think all should be well.
Peter
Downloaded a demoversion of OrCAD, now this is the complete schedule of one channel.
Although I couldn't save it like this, apparently too many nets.
It looks fine to me. But why don't you just use one relay for two consecutive tabs? Like 0 and -2dB? I think that would make the wiring easier.
I'll draw a dual-channel, single-chip version of that schematic later today (if you don't mind...) 🙂
Best regards,
Mikkel C. Simonsen
Best regards,
Mikkel C. Simonsen
Here's my attempt at a schematic: http://stiftsbogtrykkeriet.dk/~mcs/RelVol2_sch.gif
Useable for both resistor and transformer attenuators...
The PCB layout will have to wait till after dinner 🙂
Best regards,
Mikkel C. Simonsen
Best regards,
Mikkel C. Simonsen
I don't use 2 tabs because there is a difference in the switching.mcs said:It looks fine to me. But why don't you just use one relay for two consecutive tabs? Like 0 and -2dB? I think that would make the wiring easier.
When we use 4 relays there are 6 possible positions:
Code:
Pos Rel1 Rel2 Rel3 Rel 4
0 1 0 0 0
1 0 1 0 0
2 0 0 1 0
3 0 0 1 1
4 0 1 0 1
5 1 0 0 1
In your proposal we have:
Code:
0 1 0 0 0
1 1 0 0 1
2 0 1 0 0
3 0 1 0 1
4 0 0 1 0
5 0 0 1 1
There is no difference in complexity of the pcb, the transformer wires are long enough and they will be connected on the pcb right beside the relays.
I don't mind at all, the more the merrier 🙂
Best regards,
Mikkel C. Simonsen
Peter
squadra said:I don't use 2 tabs because there is a difference in the switching.
OK. But I have made attenuators where up to 6 relays change state at the same time (using one right now), and that's no problem.
Yes, but if you use resistors my option is easier (unless I've overlooked a layout option). It looks like everything will fit on a single-sided euroboard...There is no difference in complexity of the pcb, the transformer wires are long enough and they will be connected on the pcb right beside the relays.
Best regards,
Mikkel C. Simonsen
Everything did fit on a Euroboard - just.
Here's the layout:
I don't think it can be made a lot smaller/simpler than that... And when using a transformer either switching arrangement can be made using this board design I just realized.
Best regards,
Mikkel C. Simonsen
Here's the layout:
Best regards,
Mikkel C. Simonsen
mcs said:Everything did fit on a Euroboard - just.
Here's the layout:
Best regards,
Mikkel C. Simonsen
Nice, but I didn't check the traces 🙂
I've read that the relays should be at least 5mm apart from eachother to prevent them from interfering.
Maybe that's not true for all dil relays?
You could also connect the 4 unused outputs to relais for input switching.
That would lead to a 1 IC preamp wih 4 inputs and passive attenuation 😀
Peter
I didn't get any DRC errors, so if the schematic's OK then...squadra said:Nice, but I didn't check the traces 🙂
I have read that also. I also once found a datasheet that explained why. The manufacturers cannot guarantee that the relays work correctly if you operate them on low voltages, submit them to shock and strange temperatures etc. all at once, unless you keep that distance. For normal use you can place them a lot closer - and I have done so in the past.I've read that the relays should be at least 5mm apart from eachother to prevent them from interfering.
Yes, if only there was more space left on the PCB... 🙁You could also connect the 4 unused outputs to relais for input switching.
Best regards,
Mikkel C. Simonsen
OK, I also have been playing around with the pcb design package.
I have created 1/2 a board.
To get a complete channel you would assemble 2 boards and daisychain them.
Placing them on top of eachother allows me to build a really compact housing.
The pcb is 80 * 50 mm (about 3" * 2").
IC1 = ULN2803
IC2 = 74595 in SMD package
C1 = 100nF
Rel1..7 could be Zettler AZ832 or similar
Top layer:
Bottom layer:
Silkscreen:
IC1 = ULN2803
C1 = 100nF
Top layer:
Bottom layer:
Silkscreen:
- relay based attenuator
