Better OPs that have same type of pacage and are double/single version like 2064/604?? Sugestions wanted😀
Analogue stage of cd players. But my question is general beter replacement for this OPs in sound quality and specifications.mlloyd1 said:and the specific application is ...?
I'm sure this topic has been covered before in the Digital forum! 😉
But this is one of those topics where you will get as many suggestions as there are opamps in your parts supplier's catalogue. As ever, it's more a question of trying a few to see which you[.b] like the best! And much depends on how much you want to spend!
Good replacement?
I would say a boring replacement...I find the 604 more "musical".
Arne K
Upupa Epops said:OPA 134 / OPA 2134 😉 .
Arne K
Upupa Epops said:Arne, wash your ears - 604 have hearable bigger distortion and distortion isn't music.
Whoha Upupa, I absolutely agree.😎
Compared to the OPA132/2132 (or 4) the OPA(2)604 has a "raw", less defined, more "scratchy" midband and treble.
Also, the (2)132 has real BASS dynamics.
Deal?
Would you trade those for some "hand-selected" JRC op-amps?😀
Cobra2 said:-evening is spoiled anyway...
I have ~50 x OPA604 for trade/sale...
Arne K
Re: Deal?
Already have a bunch of them too...(strangely, most of them have been used...)
Arne K
Arne K
Re: Re: Deal?
Cobra2 said:Already have a bunch of them too...(strangely, most of them have been used...)
Arne K
The opa604? Definately not the op-amp for hi-end sound. Had great expectations initially, but compared even to devices like the AD847 it sounds artificial and closed-in. Nope, not for me, thanks.
I heard from Norbert Lehman that the new op-amp in the revised Black Cube Phono amp was a BB OPA 2604. The original BC used an AD OP275.
Would the 132 be better here too?
Brad-Man said:I heard from Norbert Lehman that the new op-amp in the revised Black Cube Phono amp was a BB OPA 2604. The original BC used an AD OP275.
The OPA2604 sounds better than the OP275.
Brad-Man said:Would the 132 be better here too?
Yes.😉
The 2132 (P version) is fat/wooly sounding, but it's still a little better then the 2134AP. Perhaps some like the 2132 because it fattens the rather lean/bright sound of their system. It certainly won't make anyone's ears bleed, that's for sure.
I would like to hear some opinions of the 8620.
Gaucho said:The 2132 (P version) is fat/wooly sounding, but it's still a little better then the 2134AP.
No it's not.
You just don't know how to use it.
And yes, I KNOW what you're talking about. You've hit the spot.
Hint: PSU bypass.
Gaucho said:I would like to hear some opinions of the 8620.
The OPA2132 is much better.
Hey Carlos,
I know it matters where to put the bypass, but how important is the quality/size of the cap used?
I just used what I had laying around, and it improved my project dramatically. I'm now wondering if a high quality/right size cap will even improve that.
ericpeters said:I'm now wondering if a high quality/right size cap will even improve that.
It does.
Search this forum and you'll find my hundreds (thousands?) of posts about that.😀
I suppose it's easy to find.
- Chip Amps
- Good replacment for BB OPA 2604/604
