and here comes the ZEN!!!!
My ZEN works, and, no hum
But the Led didnt work
Now i have to finish the cases.
The cubes are 20 cm wide long and hight.
@ Nelson : Thank you very much from germany.
And here are some preview pics of my ZEN:
Re: Beautiful!!!!!!!
@ Apogee: The speaker binding posts are from a german company called Intertechnik: http://www.intertechnik.com/
But Nelson uses the same speaker binding posts at his X-series, perhaps he knows where to buy.
@ Pedro: The lettering and all plates were made with a CNC machine you can find more at: http://www.schaeffer-apparatebau.de/index.htm
Reinhard
Reinhard
Joined 2002
W.O.L.F. about LED
This you might know already.
Anyway,
a LED is a component that is easily damaged.
BY
1) Connecting in wrong direction, with anything
but very low current.
2) When soldering, be careful.
Apply only as much heat as needed. It melts easy.
3) When connecting with to much voltage over it.
The same as applying to much current.
I am not totally sure about 1)
I guess your LED shows light by now.
LED:s are also very useful as Voltage references,
often used to set working point for current-sources
groman
lights up of kind people
Anyway,
BY
groman
- Zen question
