Cheap 100 to 150 Watt Amp
Sorry Sakis, but I disagree. This amplifier does work, but you wont get 100 watts out of it with those output transistors. I've had it working but only up to about 60 watts. I didn't get any oscillation and built it on veroboard as well as a PCB.
Tony
i recon ....
that you should read my posts about amplifier use or abuse .....
then on the other hand if you sup this with 30+30 vdc drive gendle loads and generally be nice to the amp ...yes this will work .... but with voltage more than 34+34 things getting critical ....also not relly omportand what kind of out you are running cause my version had MJ 11015-16 from on semi but still as rail voltage increase together instability distortion and ocilation increase .....
also there is a very big issue about tip 147 or bdv 66 -67 that can be used ...its not that they have to be matched but actually paired meaning that eventhough say that they are complementary if come from diferent factory may be P or N might have diferent charcteristics between driver and out transistor
any way i wouldnt go for an amp like that
ALL THESE
have more or less the same problems ....they have to be the same make the same small numbers ...from the same mama.....
but still this is not going to make a stable amp whats your rail voltage ????
look at mine ...so nice work but prooved to be not stable ( but i also used quiet high rail voltage.....)
That amp is a disaster waiting to happen, its been discussed here before.
The good news is after it blows up in your face, you still have the most expensive parts to re-cycle for a real amplifier (power supply , chassis, and heatsink).
Buy a pair of Pass A40 boards for $6 each from AudioXpress.com and build a class AB version of it.
I've used that board (with suitable transistors) at up to 600W/4R on ±95V.
Hi to all 😀
perhaps...
- The BDW83/84 are darlington and Vbe = 0.6x2 each bjt
I have not verified but for a bias of Ic = 10mA
it can try a series of 3 diode 1N4007 and a resistor
from 0.2 to 2 Ohms. (adjust this for appropriate Ic current)
- For better thermal stability increase Re 0.33 with 0.47 or mount
the diodes on BDW heatsink
- increase bootstrap capacitor to 47uF
- decoupling supply for differential amplifier
(split the 22K resistor in 20K + 2K and insert a cap)
- add a rc snubber on output if necessary
bye :snoopy:
Cheap and easy ... think not. Besides this thread, there are 2 more about this circuit. I red them very carefully, and this one too, but didnt find an answer for my problem. Here they are :
http://www.diyaudio.com/forums/showthread.php?s=&threadid=15415
http://www.diyaudio.com/forums/showthread.php?threadid=100618
I wanted to make this amplifier for a subwoofer, that I made, but I keep getting +21V "offset" at the output with grounded input. I used this schematic to make my PCB.
http://www.diyaudio.com/forums/attachment.php?s=&postid=179316&stamp=1053546062
Everything on the PCB is correct, and the parts are good. I only changed R7 to 1k to reduce the gain, and increased the bootstrap cap to 47uF. Why do I keep getting the TIP142 half-opened...and there is half of the positive supply at the output. I am powering with +/-42V.
How can I fix this ? Someone said, that he built this amplifier by this schematic and it worked good...well it's not !
p.s. I tried to increase R5 to 3.3k, and reduced R6 to 18k, and the offcet is about 200mv or so, but when I power it up with grounded input and 8ohm speaker connected it makes some rumbling sounds that don't sound good...and i'm afraid to connect a signal source. (my PC)
