DAC-END R (ES9018) full assembled board
problem DC-offset
Hi there,
finally the case arrived 🙂
The problem is I can't set the DC offset smaller than ca 150 mV
J+ J- removed, mute ON
Any idea?
OK thanks for investigating. US$50 sent now.
I was hoping to use that U.FL cable for synchronous clocking from my Beaglebone Black Cronus interface - the cable would connect to the 45/49 clock output from the Cronus, and I would disable the DAC's onboard clock by removing its power supply header.
Is this not possible?
