Joined 2012
DONE : was looking for a DAC at 100$/80€ , kit or not
As I will use 2 or 3 DAC in my project, I don't want to spend too much money for one...
To compare kits with other devices, kits have to be cheaper or with the power supply include.
I'd rather have a USB besides the SP/DIF, but it's not so important.
Thank you a lot if you can help me in my choice !!!
Joined 2012
Thank you to try to help me.
Input : SPDIF first, and then USB besides would be a must
Output : I don't know at all what does it means SE or balanced
if it is symmetric/asymmetric, the answer is asymmetric.
if balanced means with bass and tremble correction, not balanced !
else
PS: the description of my project is on my "homepage" (a link to a thread of the forum in fact...)
else
http://www.diyaudio.com/forums/group-buys/211201-es9023-wm8804-s-pdif-dac-group-buy.html
Shamelessly advertising our design, sorry but I did so because you mentioned SPDIF. ODAC is USB only.
I bought a Chinese special DAC/can amp called "Muse". Current top chips and it was cheap. Now, I do need to build a real power supply. It is surprisingly good. Not that you can't do better. I would say it is slightly smoother than the NAD 565 I just bought, but it may be that the NAD is more accurate. Both are "rougher" than the NAD C520 I had, but it masked how bad the CD's actually are. My big Rotel may be a tad smoother too, but they are masters of smoothing out the top edge.
Joined 2012
I bought this : just have to wait now to know if it was a good or bad idea !
24BIT/192k WM8805+AD1955+PCM2706 Coaxial Fiber Optic USB DAC Board Kit MS-1
- Digital Source
- Which DAC for 100$/80€ (kit or not) ?
