Magnatec's new line - ALFET
It seems amusing that the photos of the Semelab Mosfet packages on the Magnatec websitehave the part number used by Class D
Class-D Design Ltd.
According to Semelab these parts are 8 amps per die.
Class D rate their mosfets at 12A per die!:rolleyes:
As far as I know, these parts are not exactly the same as the Magnatec BUZ / Exicon Mosfets. They have made some minor changes to the die construction.
I would be very interested to know if anyone has managed to construct a high power amplifier, Say 500w RMS 4 Ohm +, using multiple semelab lateral mosfet output stages, that was reliable, and did not suffer from component failure.:)
Interesting choice for a name. From Wikipedia:
An alfet (Old English: ālfæt, "fire vat") was an ancient cauldron filled with boiling water, into which an accused person was to plunge his arm up to his elbow. If hurt, he was held guilty; if not, acquitted.
