A few years ago I designed a fully fledged digital sampling spectrum analyser sweep generator / controller board with double buffered screen memory that used a conventional analogue oscilloscope with X/Y inputs for the display (which I also designed around a CRT pulled from a wrecked Telequiptment oscilloscope).
This circuit board was for a HF spectrum analyser with a narrow dispersion bandwidth and a high resolution IF filter to examine the audio side bands of SSB and AM transmissions.
Digital sampling was used to accommodate the low sweep rates that are required for the high resolution (narrow) IF bandwidth, while double buffered screen memory, (flipped during the fixed 25Hz horizontal re-trace interval) provides a static visual display of the previously measured/recorded low frequency sweep on the oscilloscope CRT during each sampling sweep interval.
Preceding the ADC is a highly accurate logarithmic detector with high dynamic range (an Analog Devices part, can’t remember the part number ATM)
I’ve decided to reengineer the design for audio, with an input bandwidth of 20Hz to 200kHz. There should be a lot of interest in such a design here, so I’m entertaining the possibly of having a batch of professionally made PCB’s for the complete design made for group buy.
Now, I have elected 1MHz to be the first IF frequency and the first mixer will be a MiniCircuits doubly balanced diode ring mixer (low noise + high dynamic range).
For the first local oscillator I will use a hybrid PLL with a DDS (direct digital synthesis) chip for the divider.
The DDS allows precise microprocessor control of the frequency sweep in minute increments, while the frequency output taken from the PLL’s VCO avoids the close-to-carrier spurious frequency outputs of the DDS.
All I have to do now is to find a decent low phase noise VCO IC to cover the relatively low frequency range of 800,000 Hz – 999,980 Hz.
I do not prefer to fiddle around with a discrete varactor tuned VCO at these frequencies. Harmonic distortion doesn't matter (an LPF will fix that), but a linear response would be desirable as would a fair degree of inherent stability.
Any suggestions?
Any suggestions?
I'm inThere should be a lot of interest in such a design here, so I’m entertaining the possibly of having a batch of professionally made PCB’s for the complete design made for group buy.
Sadly I can't help you with the parts
I'm in too, that's very interesting and I also have got 2 or 3 old CRT scopes that can be used (and finally my avatar means something )
Sorry for your parts, I can't help. I don't remember I've ever seen a VCO designed for such low frequency use: don't you think you can use a good one and then divide the frequency with flip-flops?
A low cost solution: 74HCT4046 the high speed version of the CD4046 CMOS IC.
A high performance solution: TLC2933 from TI plus dividers, etc...
Would this project be (performance, cost and effort wise) competitive with a high end sound card? I can get here a brand new Lynx L22 for $600 all inclusive. Or with a second hand pro spectrum analyzer?
syn08 said:A low cost solution: 74HCT4046 the high speed version of the CD4046 CMOS IC.
I actually currently intend to use the phase/frequency detector part of the 74HC4046 (which is quite good) in the PLL, but the VCO section of that IC is horrible (fortunately the VCO section has an inhibit input).
I'll have a look at the TLC2933.
All up cost should be ~AU$200.
EDIT:
TLC2933A is a 30MHz+ part, no good.
$200? Hmmmm...
Just divide that thing by 30. One more chip to add, anyway less board space than a Colpitts + varactor.
Swept filters do not work for low frequency audio.
Real pink noise is only flat after a long integration time, even pseudo-random cylical digital noise has a very long integration time.
A) I have designed traditional audio spectrum analyers with individual filters, precision rectifiers, and integrators with guard rings on Teflon boards.
B) I have participated in the re-design of above for lower cost using digitally generated noise and computer integration.
C) I have participated in the re-design of swept-filter designs such as you are suggesting, requires lots of software to be useable.
My experience has been that A is best, B is OK for the money involved, and C is OK for controling a vibe-table, but I wouldn't want to use it for audio analysis.
I still use my production prototype of B for my audio needs.
djk said:Swept filters do not work for low frequency audio.
This instrument is intened to examine the harmonic content of steady state audio waveforms such as the distortion residual from a THD analyzer.
If you use digital sampling you can have a sweep time of 100 seconds if you want.
This allows the examination of low frequency audio signals (not possible with a 'traditional' analogue swept frequency spectrum anaylzer) using a high resoultion (narrow bandwidth) IF, as dictated by the formula.
Ro=SQRT(D/T)
Ro = maximum resolution without distortion (guassian filter response)
D = Dispersion
T = Sweep time
Glen,
take a look at this
http://uk.geocities.com/cyrilb2@btinternet.com/
Might give you some inspiration/ideas with your project.
Bottom line is most people on the forum would love an easy to build, dedicated distortion analyzer with a 80KHz bandwidth i.e. a poor mans AP.
I looked at Bob Cordells distortion analyzer but it would be a bitch to build - too many boards/interconnects etc and a lot of th e componenets are unavailable now.
Some kind of pre-processor that fed into a PC or scope is probably the right way to go in '08.
take a look at this
I built the Cordell analyzer way back when I knew even less than I know now, if that's possible. It's really not that hard, except for the rotary switches, which have to be made up from many sections and joined together. Probably expensive today. I often recommend building just the signal generator board, if one needs a very good low distortion sine generator.
Another possibility for a nice programmable waveform generator are the Analog Devices DDS chips. Maybe a AD9953 or similar, though I don't know how good the distortion is.
G.Kleinschmidt said:(an Analog Devices part, can’t remember the part number ATM)
AD8307 perhaps?
Bonsai said:Glen,
I looked at Bob Cordells distortion analyzer but it would be a bitch to build - too many boards/interconnects etc and a lot of the componenets are unavailable now.
Everything from Cordell's article is still available (including the LM1496 balanced modulator/demodulator-- this oscillator is the basis of the Tektronix SG505 -- i agree that it would be a real PIA to build the thing.
Re: Re: Homebrew Digital Sampling Audio spectrum analyser.
Hi Bonsai.
I should note that a spectrum analyzer is a rather different beast to a THD analyzer. However, my design would mate nicely to Bob's unit to examine the spectral content of the extracted distortion residual.
Bonsai said:Glen,
take a look at this
Hi Bonsai.
jackinnj said:
AD8307 perhaps?
G.Kleinschmidt]
Any suggestions? [/B]
What about the older synthesizer chips from CURTIS ELECTROMUSIC ? ONE VCO CEM3340/3345 PDF or DUAL VCO CEM3374 --> PDF
Well used also for example in the Roland's Flagship Jupiter-8
They are old but you can find still of them. Maybee in e-bay
Hi folks,
what do you think about this project with an ATmega and a graphic LCD with 122x32 pixel:
http://elm-chan.org/works/akilcd/report_e.html
Of course it won't be possible to measure distortion with that beast but it could replace the standard PA spectrum analyzer if you add a (digital) pink noise generator and a microphon preamp.
wouldn't an eval board for a 18 or 24 bit Msample monolithic ADC from Analog or TI be a lot more capable? and no 'scope needed for display - 2+ GHz 64 bit PCs should be quite adequate for dsp and display
http://www.analog.com/en/prod/0,2877,AD7760,00.html
http://focus.ti.com/docs/prod/folders/print/ads8484.html
See here:
200 MSPS acquisition board with ADC08200 should be enough
http://www.knjn.com/ShopFlashy.html
And in order to do FFT & DSP you will need FPGA:
http://www.knjn.com/board_Xylo.html
http://www.knjn.com/ShopBoards_USB2.html
In total it will come up for around $250 for freq analyzer + programming/configuring the FPGA.
D.
D.
jcx said:wouldn't an eval board for a 18 or 24 bit Msample monolithic ADC from Analog or TI be a lot more capable? and no 'scope needed for display - 2+ GHz 64 bit PCs should be quite adequate for dsp and display
I already have ~20 oscilloscopes in my workshop, and no room for another PC.
I pledge to work my nuts off over the next few weeks of evenings to get the display driver / sampling and double buffered screen memory board circuit design simplified with a little PIC here and there, using non-obsolete parts, layed out, operational and tested.
After that I will work on converting the <10Hz resolution ~90dB dynamic range analogue end and hybrid PLL working at 20-200,000Hz.
Glen
- Homebrew Digital Sampling Audio spectrum analyser.
