#41 |
It should be fine but you don't want to destroy a pair of nice speakers.
You can use anything, cheapo transistor radio speakers (at low volume) just to verify that it's working. |
#42 |
not good.... only one side gives cracling sound and way too loud....
#43 |
Not good....
If you say "Way too loud" that would point me towards a faulty volume control pot. You could swap the amplifier boards from L-R just to prove a point. If the problem stays with the same channel then the amp boards are OK. |
#44 |
can not be... I use a different amp as preamp....
#45 |
Do you know the Hiraga 30Watt amp design?
#46 |
Try swapping the input leads.
You need to ascertain where the problem lies. |
#47 |
I'll try tomorrow.... It's dinner time and it's been enough for one day :-)
Thank you so far! I hope you can help me later on? Kind regards, Sjoerd Smits |
#48 | |
just another
SjoerdSmits go back and read post number 2 and you will now understand why I asked the question
Tony. Quote:
#49 |
Hi Wintermute,
Yep, get it now! Learning all the time! Didn't know what you were trying to say with C or CRC.... :-) Thanks! |
#50 |
Now you need to find out if the problem is internal to your new build or not - hence swapping over the interconnects.
| Voltage drop across JFETs? | Test Electrix | Solid State | 3 | 14th July 2010 06:23 PM |
| Voltage drop across JFETs? | Test Electrix | Construction Tips | 0 | 12th July 2010 03:29 PM |
| How to drop voltage and current | giralfino | Power Supplies | 9 | 5th May 2010 04:18 PM |
| voltage drop across a CCS... | pedroskova | Tubes / Valves | 4 | 8th August 2005 07:11 PM |
| voltage drop | ThSpeakerDude88 | Chip Amps | 30 | 19th July 2005 09:00 PM |
