Power Supply Resevoir Size - Page 6 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th July 2012, 06:30 PM   #51
tsiros is offline tsiros  Greece
tsiros's Avatar
Send a message via MSN to tsiros Send a message via Skype™ to tsiros
Originally Posted by OnAudio View Post
something close to D.C.
don't want to sound like an ***hole, but: DC doesn't mean "constant voltage/current". Even after the rectifier it is DC. As long as it doesn't change direction, it still is DC.
Old 19th July 2012, 06:31 PM   #52
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by tsiros View Post
yeah the capacitors themselves will cost at least twice as much as the IC
I think you made a wise choice because I read a lot of people found the quality of caps in the psu to be very important.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 19th July 2012, 06:31 PM   #53
Mooly's Avatar
Originally Posted by Ian Finch View Post
Andrew posted (about a month ago) that he was taking an extended holiday. Just how extended we don't know but best wishes to him.
Thanks for that Ian.
Old 19th July 2012, 06:34 PM   #54
Default improved capacitor technology
There are very interesting caps now available
B41456B8109M EPCOS Inc | 495-4224-ND | DigiKey
Old 19th July 2012, 06:50 PM   #55
Nico Ras's Avatar
TThese capacitors are sweet as they respond fast enough in the high frequency region to buffer the interconnecting cables. Thus What the amplifier sees is a stable DC supply.
Okay Harrison, everyone describes that the power supply should produce good DC over a wide frequency range, but what affects your choice of value capacitor, it is surely not just an arbitrary number. Mind you I have seen comments on the forum like and I have xx 0000 uf caps..... results in solid bass, surely it is not just trail and error and you stop adding caps when you either run out of space or money.
Question is what made you choose these values why 33uF not 47uF or 10 uF. I would accept if you say from experience 33 uF sounds better than 47uF or if you have some formula (excuse the pun ) to calculate a specific value for a specific purpose, or a rule of thumb that has some historical significance.
So far we have a few mathematical representations and several arbitrary choices of values, then we have some including myself that feel distributed power should be used and others that disagrees - we still do not have widely accepted set of rules that confidently indicates that the amplifier/power supply combination lives up to expectations?
Kindest regards
Nico
Old 19th July 2012, 07:08 PM   #56
gootee is offline gootee  United States
Attached is an example of a power supply
The 10NF capacitor ensures that some high frequency noise is cleaned up. The rectifier exibits good high frequency behaviour (it isnt switched by the remaining high frequency noise) because the large 10,000uF shouldnt have low impedance at those frequencies. Thus we have a well behaved supply giving us something close to D.C.
Something close to D.C. will not mind interconnecting cables and will safely charge the on board 33uF capacitors. These capacitors are sweet as they respond fast enough in the high frequency region to buffer the interconnecting cables. Thus What the amplifier sees is a stable DC supply.
It will depend on the amplifier being supplied, but...
There will not be constant current from the power supply. So the supply and ground conductors will have voltages induced across their parasitic inductances and resistances, by the time-varying currents. The only question is how much.
The 33uF is quite small. With a smaller decoupling capacitor like that, the rail voltage needs to drop more in order to cause any given increase in demanded current to be supplied by the cap. Also, if a demanded increase in current is too large for the cap to supply, the circuit will attempt to pull more of the current through the power rail conductor, which will likely have significantly more impedance than the cap, causing an even larger disturbance in the power rail voltage. Whether or not any of that will be significant depends on your application.
This setup might be OK (and more like you have desribed it) for a low-power amplifier that is for high frequencies only.
Otherwise, it should perform better with more attention given to implementing lower-inductance rail conductors (shorter, or multi-parallel) and more and/or larger-value caps in parallel at the load. It would also be improved by using multiple parallel caps in place of each 10k uF cap.
Old 19th July 2012, 07:16 PM   #57
Determination of the minimum capacitance value needed at the point of load, and the maximum inductance in the cap and its connections to the load, are done using well-known methods. Well, they are well-known to the high-speed digital guys, anyway (see Henry W. Ott and Bruce Archambeault, for example). See the links I posted earlier, for the specific method(s).
Old 19th July 2012, 07:48 PM   #58
Default Minimum cap size
Here we go
Old 19th July 2012, 08:05 PM   #59
djk is offline djk
djk's Avatar
NVMOS amplifier
Candidates for the Darwin Award should not read this author.
Old 19th July 2012, 08:17 PM   #60
Default wattage has nothing to do with capacitor bank
Heres why
Valve power supply - How to size transformer? SanderW Power Supplies 25 4th January 2013 04:12 PM
How do you calculate choke size in a power supply? Burnedfingers Tubes / Valves 25 5th January 2012 12:23 AM
power supply bypass cap size BigE Power Supplies 11 5th July 2011 02:59 PM
Power Supply Case Size diymixer Power Supplies 1 10th October 2010 05:47 AM
What size power supply should I get for repair work? spooney Car Audio 3 6th December 2007 11:50 PM
Copyright 1999-2017 diyAudio
