The Well Regulated Power Supply - Page 13 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 31st December 2012, 01:23 AM   #121
andrea_mori's Avatar
The Superteddyreg
Old 31st December 2012, 01:25 AM   #122
The Salas Shunt
Old 31st December 2012, 01:26 AM   #123
The K-Multiplier
Old 31st December 2012, 01:35 AM   #124
Default Performance test
I got PCBs for SuperTeddyReg and Salas Shunt, so I can build them. I don't know if K-Multiplier PCB is available, anyway I'll build it myself.
When all regulators will be ready, TWRPS included, I'll go to a professional lab to test their real performance.
All regulators will be set to 6VDC/700mA.
Old 31st December 2012, 02:54 PM   #125
jcarr is offline jcarr  United States
With the exception of C1 being connected to ground, my impression has been that the K-Multiplier is supposed to be floating. I haven't simulated your circuit, but certainly my graphs (of the floating K-Multiplier) don't look like your graphs.
I will add that you can improve the floating K-Multiplier's input rejection performance at higher frequencies by splitting R2 into two resistors of 499 ohm each, and connecting another 820uF capacitor from the R2a/R2b junction to ground.
Also, the DDDac website has a 5V regulator solution that prioritizes input rejection performance and low noise, which you may find it worth looking at. The TIP122 pass device is chosen for high currents, and a smaller, less capacitive device could be chosen if lower currents are sufficient.
DDDAC 1794 NOS DAC - Non Oversampling DAC with PCM1794 - no digital filter - modular design DIY DAC for high resolution audio 192/24 192kHz 24bit
hth
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 2nd January 2013, 02:48 PM   #126
TNT is offline TNT  Sweden
Subscribed!!!
Old 22nd December 2013, 04:39 PM   #127
Default Revision
After several tests op amp series regulator has been abandoned for a total discrete components design.
Actual schematic consists of a pre-regulation stage made by a sort of variable zener to set the voltage, followed by a capacitor multiplier. This stage acts as a pre-regulator and isolates the regulator from the load.
Follows the feedback regulation with a single bjt that drives the output devices in push-pull configuration.
For all the pass devices have been chosen the Sziklai pair mode, for its low output impedance. Also, the push-pull halves output impedance.
The values in the schematic are for a 4-9 volts 500mA regulator.
PCB can be used for both positive and negative regulator.
Also, the PCB can be used for a DC version (without rectification and filtering), cutting the PCB along the white line.
Attached: the actual schematic, some images of PCB and finished regulator, and the output impedance simulation.
Old 23rd June 2014, 10:14 AM   #128
merlin el mago's Avatar
Ciao/Hi Andrea,
Do you sell the PCBs?
Grazie / Thanks
Felipe
Old 23rd June 2014, 12:32 PM   #129
Originally Posted by merlin el mago View Post
Ciao/Hi Andrea,
Grazie / Thanks
Felipe
Hi Felipe,
I have some extra PCB of this regulator I could sell, I have only to remember what I paid for each PCB. Let me investigate then I tell you.
If you are interested, I'm developing and SMD version of this regulator. I believe it will be ready within a month. The regulator is the same of the TH version, only rectification and filtering are omitted.
Andrea
Old 22nd July 2014, 07:34 PM   #130
cbdb is offline cbdb  Canada
Can you load it with a pulsed current source to see how much it rings?
Regulated power supply meanman1964 Everything Else 13 9th April 2007 02:50 AM
Regulated power supply akunec Chip Amps 3 5th November 2006 10:27 AM
Regulated power supply croccodillo Power Supplies 2 2nd November 2006 10:47 AM
regulated power supply adason Swap Meet 1 11th December 2005 06:32 PM
regulated power supply yugaaa Solid State 17 28th January 2003 02:39 PM
Copyright 1999-2017 diyAudio
