Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th November 2009, 04:08 PM   #221
I wonder if the regulator output cap should be at the Sense Points rather than at the FET or the Load.
If all these coincided there would be no question to answer.
regards Andrew T.
Old 7th November 2009, 04:59 PM   #222
ikoflexer's Avatar
I don't know. I need to think some more about this. In the meanwhile, at the load seems to work best for hifinutnut, so let's keep this as the suggested solution. Though I wonder how much this depends on the actual individual setup.
Any experts lurking? janneman, maximus?
Old 7th November 2009, 06:22 PM   #223
keantoken's Avatar
If the cap is across the MOSFET, it has some ESR and ESL relative to the sense point. If placed at the sense point, it has only its own ESR and the ESR of the sense wires.
- keantoken
Old 7th November 2009, 07:09 PM   #224
ikoflexer's Avatar
kt, good point.
One thing to consider here is the following. Let's call the two input points of the load Vin_pos and Vin_neg. When the oscilloscope probe is connected to the Vin_pos point of the load, it shows the wave there with respect to where the ground probe is connected. The ground probe should be connected to 0 volts (ground). However, the load does not see that voltage. The load sees the difference in potential between Vin_pos and Vin_neg, which is not the same as (Vin_pos - GND).
The proper way to observe the wave seen by the load is to have an oscilloscope with differential input, so that we use the trace seen by channel A minus the trace seen by channel B.
Old 7th November 2009, 07:34 PM   #225
keantoken's Avatar
The probe itself has what, 22pF-47pF of parallel capacitance, and some reactance depending on the cable length? I kinda doubt this would have an effect.
What kind of load does Hifi use? Is it a MOSFET driven by square wave, wirewound inductive resistor?
Perhaps pictures would be helpful too.
- keantoken
Old 7th November 2009, 10:13 PM   #226
Originally Posted by massimo View Post
You asked Iko about the strange 4uF MKT cap.... but as far ad odd numbers are concerned, you also have some uncommon values!
Joking aside, can you please specify the complete designation for the 1.1 uF MKP "blue box"?
Generally Ero/Roederstein now Vishay caps have 4 digits following MKP, such as 1822, 1830, etc. A Farnell/Digykey/other part no. will suffice.
Thank you!
I gave the manufacturer part number at the Salas v1 thread. The first item in the list and you can get the datasheet from the link: Film | Digi-Key
They have now been sold out at Digi-key.
Old 7th November 2009, 11:15 PM   #227
I think a picture illustrates better:
Old 7th November 2009, 11:34 PM   #228
If the regulator output is more inductive than the wire inductance, a capacitor placed near the regulator output may cancel the inductance, making it more stable. Or doesn't it?
With regards to different types of capacitors, it is possible that some ESR is required for damping, as Andrew T suggested. But I can't think that is conclusive, because 4 x 2.2uF polyester in parallel (ESR/4) still has a very low ESR, and they don't cause resonance. Is it possible that the ESL of the capacitor is playing up? possible. These 2.2uF cap is very small so inductance would be lower. The worse resonance seen was with the big 400V Solen which would technically have the highest inductance of all capacitors tested.
Old 8th November 2009, 03:52 AM   #229
keantoken's Avatar
There is a so-called "tunnel of death" when it comes to regulators. If the output cap has too low ESR, or even capacitance is too large, the regulator can become unstable.
"tunnel of death":
Aspen Headphone Amp
And possibly informative:
Aspen Headphone Amp
- keantoken
Old 8th November 2009, 06:24 PM   #230
MRupp is offline MRupp  Germany
MRupp's Avatar
I happen to have the Jung SR file handy from the time I built it. Here's the noise simulation. I'm reluctant to take seriously any noise simulation, hence, I'd consider the noise simulation only for its entertainment value.
Hmmm, not as bad as I thought. I simmed a very simple differential-amp series regulator (almost identical to the one in the Pass Pearl phono pre), then converted that into a shunt version (with CCS in front off course) and compared the noise figures in LTSpice. They were pretty much identical and I am beginning to wonder, too, how good these simulations are.
Off course, the shunt regulator's line rejection was much better - due to the current source, but when I cascaded 2 series regulators rejection was again in the same ballpark. If anything the shunt reg had a small advantage at higher frequencies.
Martin Rupp
The simplistic Salas low voltage shunt regulator ikoflexer Power Supplies 4802 11th February 2012 01:16 AM
Tube for a shunt voltage regulator jarthel Tubes / Valves 14 26th October 2006 05:19 AM
Page generated in 0.12845 seconds (78.02% PHP - 21.98% MySQL) with 11 queries
