The simplistic Salas low voltage shunt regulator
Reflektor Advanced +4.7V
Sorry not +5.0V, but +4.7V. 😱
My WaveIO board is running with this config. and seems to be good.
It will be the DCB1 reg schematic to implement. But with 4 leds in the CCS. That one has been used up to 3A. The dissipation is going to be Vin-Vo times full set current for the CCS Mosfets (very hot) while the dissipation for the output Mosfets is going to be Vo(12V) times (CCS-load current). Setting the CCS should be mean average at load plus peak demand and 200mA spare. Do it on air p2p like a high power valve circuit with thick copper wire connections for the rails and grounds and don't rely only on solder to hold hot stuff. Twist and screw where heat is much. Keep any electrolytic as cool as you can and use only 105C parts.
Kazuo san,
I'm glad you've improved the reflektor. I am planning to try the new version. However, I don't have STP55NF06L at hand. Can I still use MTP3055VL as M3?
Thank you for having you be interested in this circuit🙂
Simulation says MTP3055VL is not good, because the output impedance does not go lower sufficiently. However spice model is not real world. It may be worthy to try.
But I recommend STP55NF06L at present.
BTW some advice.
Improved Reflektor is going on experimentation, having both merits and demerits. I will plan to change some config.
Cheers
Voltage Reference - Shunt Voltage Reference - LM4040A20 - TI.com[/url]
pro/cons with passive stuff?
The noise density from LM4040 is 35uv/rms (10hz-10khz) which is already much higher than some LDO's. For instance, LT1763 has 20uv/rms from 10hz-100khz, and NS LP5900 is even at 6.5uv/rms. I am thinking about using Onsemi or Sipex TL431 as the 2.5V Vref. Those TL431s have very low noise internal Vref (around 50nv/hz @10hz - 40nv/hz @100khz).
You will need a 4th LED on top left so to have some margin for easier R1 values since the Vgs is going to be higher in the current region you aim at. You gonna need a 6th LED in the middle for 12V. You use red 1.9V Vf LEDS. You may skip R4 & R5. On the positive one change the connection of Q6's gate for going to ground instead of D pin. Going to D is a Mez DCB1 specific trick only. For circa 4.3A CCS you gonna need 0.56R R1 (ballpark). That resistor is gonna dissipate ~10W(!) so use a sinkable one. Maybe a Caddock.
Niko I have added a 47uF cap at the output of the BiB right on the Shigaclone PCB entrance and noise has dropped to about 10mV
attachment.php
But hitting auto gives me this...
attachment.php
It is not detectable with shigaclone off
Can you please advise? Do I have to worry about this?
C103 is FR at 47uF, R107 is 0R47 and cap at the power entry point is FR 47uF
Thanks again
