Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th January 2010, 07:21 PM   #861
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Joshua_G View Post
Thanks, Salas.
Modified schematic attached.
Any comments are welcomed.
Would it be safe to adjust the output voltage without any load?
Or is it better to use a dummy load, say 220V 100W light bulb?
I prefer a dummy. It will be hard on the shunt element without. See to use an Ohmic load that will consume about 45mA (analogous to 2x6V6 pre channels). That is 15W dissipation. Maybe 2x 15k 20W resistors in parallel. What kind of Ohmic value that bulb gives when hot?
P.S. Having 175k, set the trimmer around 200R before installation, should get you to your target when going lower. Don't start high trimmer, so the Vdif will not tax the components until you fix it.
Old 8th January 2010, 07:45 PM   #862
analog_sa's Avatar
Originally Posted by Salas View Post
Did you do the Jfet Vref mod BTW?
No, just learned from Goshu_G's circuit above about it. Busy with another project at the moment but i can see more of your regs in my system soon
Old 8th January 2010, 07:50 PM   #863
Salas's Avatar
If under 300V read some pages before, its with MJE350 and tested. Joshua is going to use a 400V smaller dissipation driver transistor and simulated with some differences in values, so its to be seen if it will work OK or it will need mods.
Old 8th January 2010, 07:52 PM   #864
100W light bulb is way too much, 15W is closer to 45mA current draw. I'd rather use resistors. Anyhow 340V supply may well burn 220V light bulbs.
Old 8th January 2010, 08:05 PM   #865
Indeed, there is nothing to learn from my suggested version of the circuit, since I didn't build it yet.
Old 8th January 2010, 08:12 PM   #866
Salas's Avatar
It will probably do well. But we wait for your feedback.
Old 8th January 2010, 08:18 PM   #867
Feedback will be posted once the regulator and the amp will work. Right now I'm ordering parts.
Old 9th January 2010, 04:04 AM   #868
Send a message via Yahoo to quanghao
Default THe simplistic design by SALAS
Hi Salas, Hi all
With the acceptance from Salas, I have made some testing boards for me and gift for interested members. Please log in your name and address for sending. Thank you Salas, thank all
1. Nicola =1
2.Jean-Charles=1
3.DUC985=1
4. Mathias=1
5. Joshua_G=1
Thank you very much!
http://www.audiodesignguide.com
Old 9th January 2010, 09:32 PM   #869
Salas and all,
Which 1u 400V capacitors do you use, or recommend?
I believe that the selection of this capacitor should make a difference, not less than the capacitors used in the rectifier's filter.
Old 9th January 2010, 09:33 PM   #870
Salas's Avatar
Wima, Rifa, Vishay, MKP if possible.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Regs - Shunt vs Series richie00boy Solid State 4 27th November 2003 07:09 PM
Page generated in 0.11585 seconds (78.56% PHP - 21.44% MySQL) with 11 queries
