Simplistic Mosfet HV Shunt Regs
Old 31st August 2011, 05:55 PM   #1961
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Originally Posted by Stixx View Post
Oliver, there is only one Zobel cap...
PS. Do you recognize your board?
Sure i do Looks cool with the red JENTZEN caps.
I still have the Mundorf M-Caps on my personal boards. Perhaps i try a M-Cap supreme....
BTW, i've got some 1K0 bulk-foil trimmer from Texas Components. Let's see if it perform better as the standard...
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 31st August 2011, 05:55 PM   #1962
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The board I was using apparently was based on this schematic...
Yes, that's the one linked from post #1 as the evolved one. Some use clamping diodes on the gates as I have shown also, some don't, but there is no appreciable failure rate reported here with either.
Old 2nd September 2011, 01:32 AM   #1963
yjc68 is offline yjc68  China
The transformer looks well !
Old 3rd September 2011, 05:57 PM   #1964
hihopes is offline hihopes  South Africa
Hi Salas,
I will be needing a few boards soon. Any news on the new boards? Or else where can i currently get boards please?
Old 3rd September 2011, 06:53 PM   #1965
Salas's Avatar
Right now nothing new. Will take time. Currently there are two guys, one green one red, obvious in the last posts. I can't make recommendations, you choose.
Old 14th September 2011, 11:45 AM   #1966
Now the 1260W 1K0 Bulk Metal Foil Trimmer ($29.29 from Texas Components) is installed.
Very interesting... The bass goes deeper and is more precise than with the standard trimmer.
For source information about the Bulk Metal Foil Trimmers, look into my Blog.
Additionally the 1F of the Zobel is bypassed with a 0,047F/500V russain K72P-6 teflon cap.
I have also changed the heatsinks to a bigger one, to have a bit more "Air" for shunting
The result astonishes me! I think thats the last tweak on my SSHV modules.
Now its really time to design the case for the whole DAC.
Old 15th September 2011, 11:34 AM   #1967
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Oliver your 1260W +-10ppm TCR trimmer is 10% or 5% tol.? Actually I use 1280G 10% 15ppm. I asked Texas Instruments price for Vishay 1285G 1K trimmer +-5% tol. +-5ppm TCR, 1260W at 29$90 USD sounds high priced considering 1280G cost 12$50 USD if you buy from Michael Percy Audio.
Old 15th September 2011, 11:38 AM   #1968
Salas's Avatar
Why don't you just measure the final set value and then put a good same value resistor in its place?
Old 15th September 2011, 12:03 PM   #1969
My trimmer is a +-5% tol. one.
Also a possibility, but i want to be flexible for different tubes and
to check different tube rectifier!
Old 15th September 2011, 01:18 PM   #1970
That's a good idea if regulator it's only for an application, fixed resistor can give exact value as a trimmer except if you buy a "on request value" naked Vishay....
Simplistic Mosfet HV Shunt RegsHide this!Advertise here!
Regs - Shunt vs Series richie00boy Solid State 59 17th June 2017 04:59 PM
