ESL - Where does one start??? - Page 2 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 11th January 2005, 07:27 PM   #11
Calvin is offline Calvin  Germany
Calvin's Avatar
Simon, I started the same way Years ago
And though the result was really much better than I had expected, I now know, what lacked. The problem with ESLs is, that they are so far superior to dynamic drivers (in the mid-highs) that even quite "bad" ESLs sound much better. But having a really good panel the differences are breathtaking. One of my prime design-goals is efficiency. Like the dynamic fraction, ESLs sound much more lively and dynamic when efficiency is high. Therefore You have to get rid of the imo totally wrong fullrange thinking. Bass is the only region where dynamic drivers give better results than ESLs (when it is done properly), build much more compact and where You get the least problems with crossing over. As soon as You shift the working range of the ESL in areas where it doesnt need to move (basically above 100Hz) the sound becomes cleaner. But the really great advantages are:
-less D/s which risens the efficiency significantly
-lower voltages, polarising- and more important signal-voltage
-lower step-up-ratio, improving bandwidth, and dynamics as well as headroom and/or allows for simpler or cheaper construction
One of the biggest mistakes that a DIYer can make is to think that a lot of D/s-spacing is of any use. It kills dynamics, it costs efficiency, costs bandwidth, costs safety! Build Your ESL with a as small as needed (+ a little reserve for tolerances) D/s-spacing. As a rule of thumb. A panel with 0.3m, working from 200Hz on needs just 1.0mm and can give efficiencies of up to 90dB/2.83V/m with an ratio of 1:40 (depending on the polarizing voltage)
If You want to extend the frequency range down to 150Hz a D/s up to 1.5mm is useful (Id opt for more area than more D/s).
At 100Hz, 2.0mm and an area of min. 0.6m.
This way I build Panels with efficiencies around 100dB!! Imagine the outstanding resolution of an ESL partnered with the lively and highly dynamic sound of a big Horn!
jap
Calvin
Old 12th January 2005, 05:20 AM   #12
blu_line's Avatar
Default segmentation
@Calvin
thnx for sharing the experience !
How did you solve the segmentation (beam forming) ?
1. More smaller panels
2. group stator wires
My full-ranges are somewhere on an attic. But i am planning to build hybrids some day. Your story supports my thougths. Smaller panels is the way to go !
grtz
Simon
Old 12th January 2005, 03:43 PM   #13
many thanks to all who have replied
But I'm still wondering about the cost... I don't know squat on how much it could cost (200?, 500?, 1000?). And especially: would I be better off starting these things from scrath or should I buy second-hand and mod?
SMILE
Old 12th January 2005, 05:09 PM   #14
Calvin's Avatar
Default cost
its quite difficult to give numbers as long as certain conceptual points have not been cleared.
e.G. Wire Stators. If You try to build a big one You might use ordinary cheap PVC-coated wire for home installation. Its labeled H07-VU. But You need a high polarizing Voltage and high signal voltage, which means You have to buy a very good and costly audio tranny (the transformation ratio should be around 1:100). Plastics for the Spacers are easy to get and very cheap too. Leaves You with the cost for a piece of diaphragm amd glue.
building smaller ones You can work with magnet-wire or Kynar-insulated wire which is more costly than PVC-wires, but gives higher efficiency. But watch out how much meter of wire a pair of panels really needs (can be several hundrets!).
Building perforated metal sheet stator the cost for the sheets and their insulation is relatively high. The polarizing voltage is lower (the power-supply probabely a little bit cheaper). Because You need less signal-voltage the transformer ratio can be lower and the panel may even work with standard off the shelf toroidal trannies (which reduces cost substantially, because the trannies are most often the costliest parts). Using plastic spacers the cost is low, using the 3M foam-tapes will cost more.
You can build ESLs for just a few Bucks or for thousends.
Best is to write down a materials List and calculate different possibilites. Start with known commercial ESLs. Try to figure out what they are made from and what it would cost You to copy such a thing. Ask Your local metal/plastic dealers, DIY-shops or internet to get Your numbers straight. Ask in Forums about construction/material-details etc etc. Youll quickly see what Your favourite concept could cost You.
But no one can tell You the cost like "And the solution is........... 13!"
so 200, or 500 or 1.000 are the correct numbers.
Modding/repairing a existing panel could be done without deeper knowledge about materials and theory. Building a panel from scratch You really have to get involved with the matter.
So You have to decide, how far You want to go and how much engagement You are willing to spend. Do you want to be an expert, or is the highly specialized user Your thing?
jap
Calvin
Old 12th January 2005, 05:35 PM   #15
Did it Himself
richie00boy's Avatar
You might want to check out ESP Project 105
Old 13th January 2005, 11:34 AM   #16
kavermei's Avatar
Send a message via MSN to kavermei
Hi all,
I'm currently building my first pair of ESL's. I'm finishing the panels and then I still have to do the electronics and the support frame.
Some thoughts:
* I built wire-frame stators, and it took A LOT of time!!!... I think if I ever build another pair, I'll do perforated metal stators. They'll be a bit more expensive, but they can be built in MUCH less time.
* Cost: In total the pair of speakers will have cost me about 800...900 Euros. But I had to buy some new tools as well, and I used expensive audio transformers (because it's a full range design). So I guess without the transformers and tools it will have cost me about 300...350 Euros
* I had some trouble finding certain parts or materials, e.g. adhesive copper foil. I found that sourcing all the necessary materials was the most frustrating about this project.
* Build time: several months' weekends work. Often you can only do a little work and then the paint or glue has to dry so you have to wait a whole day, so sometimes progress is very slow...
When my speakers are finished (still plenty of work to do ...), I'll post some text & photos on my homepage.
Happy building,
kenneth
Old 14th December 2014, 11:56 AM   #17
halo,mister the link pdf in post number 4 is not found other link,please,mister
Old 14th December 2014, 01:20 PM   #18
If you are interested in the theory behind electrostatic loudspeakers, also check Frank Verwaal's website:
Elektrostatic Loudspeakers - Frank Verwaal
Old 16th December 2014, 10:21 AM   #19
good2
dankeuw,mister
Old 16th December 2014, 12:07 PM   #20
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
Send a message via Skype™ to Bazukaz
Originally Posted by kavermei View Post
Hi all,
Some thoughts:
Happy building,
kenneth
The amount of time and money looks normal when you are trying to make everything in a more or less correct way.
Long time ago I have started with perforated metal.After half a year of experiments switched to wire stators. And never thought about perforated sheets again. Beaming, arching and sometimes leakage were the main problems. Of course it could be done, but it's no way an easy job. So let's try to make a comparison of main differences in construction :
Wire stators:
a) Building wire support frames(time consuming)
b) Stretching and gluing wires(somewhat time consuming, depending on tools and techniques used)
c) Radiation pattern control by using electrical segmentation(relatively straight forward)
Perforated steel:
a) Insulating perforated metal to prevent arching. This is in my opinion one of trickiest parts; very few powder coaters will be able to do the job well enough and with correct materials
b) metal sheets should be either curved or have supports to increase structural rigidity
c) radiation pattern could be controlled by either curving or using mechanical segmentation
Of course perforated sheet panel could be made without steps a,b & c but IMO in such a case it's more a test of concept than a serious speaker that is expected to work for years and is not a big headphone(what is the purpose of a speaker which needs your head to be anchored ..? ) or a cardiac arrest machine for those who are curious touching things with their hands ..?
So IMO you should not expect something much easier with perforated steel(perhaps coutrary..!).
Perforated metal has another significant con: typically much higher capacitance compared to segmented wire esl(also spacers can eat a lot of it).
Also I can not see a reason why wire stators should be less sensitive compared to perforated metal, given that area, spacing and other parameters are the same. On the countrary - round shaped wires are less prone to arching and could be driven with higher voltages which means higher maximum SPL.
Where to start? mattmcl Chip Amps 3 18th May 2009 07:49 AM
Will start my new Gainclone from Start, Need Help samsagaz Chip Amps 4 27th May 2008 09:39 AM
Where do I start? twowheeled Subwoofers 18 10th January 2008 03:52 AM
Where do I start? damonpip Pass Labs 23 18th April 2006 08:58 PM
where to start?! samsagaz Solid State 1 30th August 2004 05:30 AM
Copyright 1999-2017 diyAudio
