Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 29th January 2012, 10:30 PM   #111
cfb is offline cfb  United States
Yep, those are the series 2 JansZen tweeters in addition to the gray pvc stator frame the insulated stator wire is wound around each frame and then the two are bonded together with the mylar diaphragm sandwiched between them. In the older series one JansZen panels the stator wire was cut and bonded to the inside only of each black pvc frame. This main design difference was done for the ease of manufacture. A higher speed winding machine could be used and there were less rejected parts due to misplaced or out of alignment stator wires.
In regards to the history of Wilson Audio and the WAMM, of course John Curl could supply far more information as it was he who extensively rebuilt and modified all of the Crown EQ-2 equalizers that were used as part of the WAMM system; in addition, I believe, to the active 2 way crossover that separated the signal to the subwoofer units and the mid / high frequency tower amplifiers. The system had to be bi-amped. If anyone cares; the 18” subwoofer driver was a custom OEM unit supplied by the German company Magnat probably best known for their plasma tweeters they manufactured in the 1980s.
Old 30th January 2012, 07:31 PM   #112
kevinh is online now kevinh  United States
Originally Posted by cfb View Post
Sorry that is not correct; it was Arthur Janszen who designed and was granted U.S. Patent 2631196 back in 1953 and founded Janszen Laboratory in 1954; for trademark purposes the letter Z was always capitalized to distinguish between the esl tweeter the JansZen and the name Janszen. He licensed the design to the Neshaminy Electronic Corp. in 1959, which manufactured the tweeter up until the mid 70s. Arthur Janszen became a vice president of KLH; which was of course, Henry Kloss, Malcolm S. Low, and J. Anton Hoffman. It was Arthur Janszen who was involved with the design of the famous KLH 9 electrostatic loudspeaker. After the 9s came his Acoustech X speaker the”x” standing for 10 of course. In the mid 1970s Mr. Janszen developed a hybrid esl speker for Electrostatic Research Corporation; unfortunately that venture was not successful. Mr. Janszen eventually left the audio industry to pursue other interests.
When Neshaminy Electronic Corp., ceased manufacturing in 1975 the corporation's assets were acquired by Electronics Industries and it is here where Dr. Roger West enters the picture as Dr. West was employed by EI to design a replacement tweeter to the original Janszen esl panel. However, Dr. West left Electronics Industries and in 1978 founded his own company SoundLab, so his involvement was less than assumed. Furthermore, he never collaborated with Arthur Janszen on esl panel redesign.
What confuses many is that Dr. West used an esl panel with the visual appearance of a JansZen type tweeter for his SoundLAB Marquee center channel speaker but that panel is not a Janszen or RtR but is Dr. West's own design. Furthermore, Dr. West's SoundLAB Marquee speaker came out far after the Wilson Audio WAMM had come and gone. The SoundLAB Marquee after all is a center channel speaker introduced during the 5.1 home theater and surround sound era of the home audio market.
By 1980, the tooling and rights to the JansZen tweeter design were acquired by Don Kliewer of Winslow Industries. It was Mr. Kliewer's Winslow Industries that supplied as an OEM all the tweeter panels for Wilson Audio's use in the WAMM aka Wilson Audio Modular Monitor, during its production in the 1980s. When Mr. Kliewer passed away the tooling for the tweeters languished for a few years. A fact which certainly contributed to the discontinuation of the Wamm design. The loss of a source for the esl tweeters and the difficulty Wilson Audio had in stocking replacement KEF B139 mid-woofers certainly mandated the decision to retire the design. Wilson Audio needed to maintain their existing stock of drivers for the service and repair of Wamm systems already out in the field.
By the way, Mr. Kliewer had also acquired the tooling for the RtR tweeters, which was JansZen's main competitor back in the 1970s and thus confusing the issue as to which tweeter one is referring to, a JansZen or RtR or possibly best just to call them a Kliewer tweeter at that point in their history. Visually the JansZen tweeters were either black or grey pvc stator frames, later production light grey, early units were black. This is in contrast to the RtR stators which were often blue or green pvc; you will see the green type in the Crown ES series, a 1970s hybrid speaker. The RtR tweeter arrays were also used in the famous Fulton J Modular speaker which may have helped to inspire the Wilson WAMM system. It was the RtR tweeter that was used in the early Infinity Servo Static esl speakers. The midrange was Infinity's own design and was the source of much failure in the Servo Static 1 and 1A models.
To confuse the issue more by the late 1980s Mr. Kliewer interchanged the pvc he used, probably due to what raw pvc he could obtain, the economics of small volume production at play here, as a result some of his tweeters do not follow that color identifier. When Mr. Kliewer passed away there were only around 150 pairs of tweeters left as unsold stock which the estate liquidated. I assume most of these were acquired by Wilson Audio for repair parts but maybe not, who knows.
Arthur Janszen's son David who resurrected the JansZen company name in 2005 was able, I believe, to reacquire the original tooling sometime around 2006 but Mr. Janszen could clarify that matter. Also, as David Janszen will tell you the coating on the JansZen tweeter's mylar diaphragm was always more complex than simply graphite a point which has sometimes been mistakenly made.
I hope this bit of audio history was informative for some but probably very boring for most here.
When Roger was in Salt Lake City in the late 70's I bought a pair of Z50's from him, before he built the R1's under the Sound Lab name. The way he has taken the A1 panels and refined them over a 30yr+ period is truly remarkable.
You know more of the details than I do.
Old 30th January 2012, 08:41 PM   #113
Default straying a little
Over the past several evenings I have beem perusing the Elektrosaten ESL club website. The Dutch and Germans seem to be heavily in to ESL DIY construction.
One program listed as "esl_seg_ui" keeps getting mentioned. As I understand it, the program assists in predicting wire stator panel response under various parameters. Has anyone used this program, and can it be found in an English version?
Now, back to woofers.
Thanks to those who are contributing the history. RtR cells were also used by ESS (then Electrostatic Sound Systems) in thier "Super Quad" and "Transtatic" models. They played around with JanZens, but as I remember there were some reliability issues. When the Heil device was introduced, they changed their name to "ESS" and dropped the 'statics altogether. I also remember the Servo Statik- I had a freind who owned about half a pair of them. He owned the tweeters and the sub and Infinity owned the mid panels because that's where they spent most of their time.
Neat subwoofer, though- as close as anyone in our crowd got to hearing the Servo Statiks was that sub and Stax headphones together.
J
Old 30th January 2012, 08:47 PM   #114
ANother history tidbit- Bill Johnson first marketed his tube amps under the label Electronic Industries Div. Peploe Inc back in the early '70's.
Old 30th January 2012, 10:37 PM   #115
Default Geralds' efforts
I gotta say, after reading about GFJR's adventures, I am pumped up. I can see a lot of you have done this, and your input is helping me in my quest.
J-
Old 31st January 2012, 01:16 AM   #116
He,he,he,he, I am very glad to see that I have raised such an enthusiasm as that is my very intent indeed.
I must say that it has been along time passion to be finally seeing these projects a reality.
But, I must also give credit to those In these threads whom have help me out tremendously as well.
The list is too long to name each one individually.
Just two years ago the only thing I can say that I really new about transformers was how the transformation ratio worked and the rest was a mystery.
Knowing also, this was the key to and stopping me from finishing my system.
I had to embark on what makes them tick and this is were the DIYaudio community really kicked in to help me understand this mysterious beast.
Ever since I could hold a pencil I replaced it with a soldering iron and In the mid 70's was when High end audio started to come about.
Occasionally I would see the schematic of some high power amplifier and I would say to my self "They want $1000 for that thing!" and I would tally up the price of the components and in most cases it would have cost me much much less than $200 for one or two of them, not to mention quantity's of 10 prices.
Being transformers and heatsinks the most costly of component,just as it is today.
Although $200 was a gracious amount of money in those days and I did with what I had at the time as well keeping up with the latest technologies through the years.
It was when I saw a write up in Popular Mechanics Magazine on the Quad and Magnepan planar speakers that really got me going and again saying to my self "Is That All There is to Those Things?", that's what got my guff and my journey began.
Not to mention a really old HI-Fi book that mentioned the mysterious ESL and Plasma speaker technologies that I found in the school library and stuff on tesla coils.
At this point H.V. became my newest quest as all of these things are exactly that, H.V devices.
Back in those days we didn't have vast limitless tank of information called the internet.
It wasn't until I had found Roger Sander articles of DIY ESL's reprinted in a book called The Audio Amateur published in 1980.
Copies of his articles can be found on his website.
I Can't even start to explain the joy and nearly started sobbing when I had discovered the chapters in that book fully describing several systems.
It was the moment of a brand new meaning to the word "WoW, I can not believe what I am looking at !!".
Remember this was nearly 20 years before the existence of this very forum.
And, It took me that long, almost to the year, Of the discovery of that one book when I finally built my first working pair of panels.
The very first time I had actually heard commercial set of ML's was just a few weeks before I had finished mine in 2003.
I had already been accustomed to the Apogee's for some time so I knew what to expect. But, I wasn't expecting to be blown away by the multifold in clarity.
This drove my passion for these things X squared.
Finding the proper materials was very difficult through the years as I didn't find the .25mil mylar until about 1992 from an ad in PM for company that supplied materials to build ultra lite aircraft and they were having a going out of business sale.
It was around 1998 the internet was starting to come around and I had started to discovered all of the websites oversea's featuring ESL's.
I printed off every thing I could find and I still have them stored in a box.
Complete projects from the TAC website when the were still displayed.
And because of the net, Info on materials and resources suddenly became very easy to obtain.
At that time I lived in Naples Florida and things were quite setback from the rest of the world back then.
So, when I tried to explain to someone what I was trying to do,Welllets just say that it was hard for them to understand or willing to go out of their way to get the info that I requested and told me good luck.
This was very hard coming from the very same area I now live in,But I pushed on anyway.
I like to use the words "simple" and "easy", Calvin cringes every time those words are mentioned.
Truthfully I can't blame him as it has been a bit of a long road to learn all of the how's and why's and what don't work.
But structurally it is no different to building a model airplane kit as it they do have a lot in common with lots of challenges to overcome to have a decent and reliable product ( I do mean ESL's).
Just like an Ole' Boy used to tell me back in the days of being a chef,
" It is easy when you know how Fry it's easy when you know how"! he,he,he
I will never forget that !!!
Keep on DIYin' !!!!
jer
Old 31st January 2012, 07:47 AM   #117
Calvin is offline Calvin  Germany
Calvin's Avatar
kevinh: As to conventional SW performing "way batter" you have no basis for that assertions since you clearly have never heard the B1 of B2 panels...
Sorry, but whats Your basis or expertise then? Is there a theoretical backup You might want to share with us?
Did I say anything about conventional SWs? No, talk was about dipolar woofers! Its the dipolar feature that gives the drum-like ESL membrane an acceptable bass in room at all. If a classical (monopolar) woofer would perform with a comparably high Q as nearly all ESLs do, nobody would grant them good performance. Instead they´d be dismissed as lowquality right away.
On the other hand does a dynamic dipole profit from the superiority of dynamic drivers in the bass region AND the dipole character. A dynamic dipole woofer knocks out ESL bass with regard to precision, dynamics, linearity, compactness, drive demands (ohh, I remember repeating myself here )
I also think it somehow funny that a person unknown to me, explains the world what I have listened to or not have listened to and how well my listening sense works.
jauu
Calvin
Old 1st February 2012, 08:13 PM   #118
bolserst's Avatar
Originally Posted by kevinh View Post
Speaking of the Sound Lab Panels he uses a distribute resonance described here
Sound Lab Technology: Distributed Resonance - a patented advancement in electrostatic performance
It was recently pointed out to me(thanks mike beck) that all 8 claims in the Sound Lab patent were cancelled in 1994 when the patent was rexamined.
See the last page of the attached patent US5054081.
Perhaps it was discovered that Magnepan's 1972 patent (US3674946) already taught the technique of distributed resonance for planar ribbons. See Figure 12 & 13 for details of diaphragm sectioning and resulting distributed resonances. Applying the concept to ESLs, perhaps, was not deemed novel enough to warrant a patent.
Old 14th February 2012, 08:29 PM   #119
CAUTIONARY NOTE- DO NOT be tempted to try to download any of the numerous .rar files of the ESL Design Cookbook by Sanders- All of those sites are bogus. The self extractor they bundle with it contains serious malware to steal your financial data.
Old 14th February 2012, 09:35 PM   #120
geraldfryjr's post was wonderful reading and many happy DIY ESL memories flooded back.
I built a Sanders-like amp to drive Dayton-Wright elements and later, whole D-W intact speakers. There is a big difference between cones and ESLs and there is maybe a comparable difference between driving with a Sanders amp versus step-up transformers. No kidding.
Pity those kinds of amps are so potentially lethal. But given the sweat devoted to some minor tweaks in sound creation, sure funny that people aiming for the best sound don't insist on direct-drive high-voltage (2400 V B-plus) amps.
The new book by Nobel laureate Kahneman discusses in much detail the illusions of expertise as well as how faulty our judgments can be. I am sure the voluminous (and Nobel-winning) research he recounts will be entirely wasted on those who judge their own creations with their own ears (esp. persons of an engineering cast of mind... I won't pick on any specific nationalities or language groups because that kind of obtuseness is widespread) but thought I mention it anyway for others.
Ben
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), Klipschorn mixed-bass woofer w/param. EQ plus 1954 AR-1W or giant OB
HiFi construction since 1956
Janszen Model 1 (New ESL & Woofer Arrangement) bolserst Planars & Exotics 22 12th November 2009 09:42 PM
(sub)woofer for esl justice strike Planars & Exotics 15 1st September 2009 08:58 PM
newbie needs help with dipole woofer hybrid esl CharlieM Planars & Exotics 4 26th February 2008 10:03 PM
woofer array for ESL? Few Planars & Exotics 2 15th April 2004 04:39 PM
Best 500Hz and down woofer for pairing with ESL? Bas Horneman Planars & Exotics 55 6th August 2003 01:44 PM
Page generated in 0.15935 seconds (87.76% PHP - 12.24% MySQL) with 11 queries
