Planars & Exotics ESL's, planars, and alternative technologies
MartinLogans New/Old ESL Panels
Old 20th November 2011, 04:36 PM   #1
tyu is offline tyu  United States
Default MartinLogans New/Old ESL Panels
There Speakers Panels were Made in 2001-2002
We have In the panels befor this time like the SL3 an others, the rubber in the spacer is thicker an softer....from 2000 on the {Lexan} is a harder rubber type.....About half as thick....one thing took a min. to get the panel pulled a part.....with No nicks in the mylar...the older panels were hard to get a part....an most of the time you would get a rip in the mylar... but most of the time you had nothing to lose....the older would lose it coting...so you had it put on High V coting to get them to work agin... sope work good grafit.. here is pix of the new panel spacer...Now with the new Mylar... it so thin if you put any coting on it you lose SPL...output drop off fast...i DONT think You can Recote..the new panles i have after a good wash an cleaning work great like new...no loss of coting after 11years....But the older panels can sound great an be recoted over an over....an the MIDs sound a littel sweeter..softer rubber....I need more time with the newer panels.
The info is from Stereophile v24n7.... vary cool maylar the highs are better than the older panes an you get more output from smaller gap.This info is for the diy in use...
MartinLogan's CLS screens are arc-proof. Sanders and his engineers determined that panel arcing was due to local buildup of charge from uneven coatings on the 0.0005"-thick polyester diaphragm. While other manufacturers hand-paint diaphragms with a conductive material, MartinLogan vapor-deposits the conductor as a 1-angstrom-thick (0.0000000001m) layer onto the diaphragm's surface. This process produces an optically transparent conducting layer with uniform characteristics of surface resistivity that prevent charge buildup and migration, and arcing. According to Sanders, this layer has the electrical surface conductivity of human skin, allowing it to hold a static charge of from 1500V to 3000V.
The Prodigy's diaphragm is sandwiched between perforated steel plates, called stators, that carry the varying audio-signal voltage while providing insulation to protect the user. A nylon-based powder insulation is deposited at very high temperatures on the perforated steel stators to provide a safety tolerance of 12kV. Fourteen evenly spaced ClearSpars, or horizontal Lexan insulators/spacers, subdivide the panel and create a uniform gap between the stators and the diaphragm. When the amplifier's audio signals are stepped up to high voltages by a transformer and applied to the stators, an electrostatic field of opposing voltages produces forward and backward movement of the diaphragm, which in turn generates sound waves in air.
One problem with electrostatic speakers has been the tendency of the charged membrane to collect dust. However, the Prodigy's diaphragm accumulates dust only slowly because it automatically shuts down its electrical field when no music is playing. When dust has accumulated, the manual advises the owner to leave the speaker unplugged for 12 hours, then vacuum the
Old 21st November 2011, 12:19 PM   #2
Default more looks
Heres the Mylar...
Old 21st November 2011, 04:30 PM   #3
I sead...
...i DONT think You can Recote..the new panles i have after a good wash an cleaning work great like new....
Well i thought i would get hit on the
...Cant Recote.....you CAN recote any ESL Mylar!...
Now you can an must Wash any ESL....make big Diff, get rit of Dust....
Old 26th February 2012, 06:47 PM   #4
pongola is offline pongola  South Africa
Hi
I bought a pair of Sequel II's very cheaply as they were not working. I had a friend pick them up and he drove them the 600km in an open pick up. He was very apologetic when he arrived as he had been caught in a rain storm. This storm did the trick as they appear to work perfectly now. They were previously at a coastal location which may have have affected the coating
Old 26th February 2012, 10:39 PM   #5
Hope the SeQuel low end driver an wood box held up...one way to give them a wash ....But you may get more out of washing the front an back..but what ever you think... it works
thanks have fun
MartinLogans New/Old ESL PanelsHide this!Advertise here!
New ESL panels clicking dochungwell Planars & Exotics 19 31st October 2011 01:35 AM
subs for esl panels slr 5000 Planars & Exotics 14 2nd April 2011 09:38 PM
different ideas for ESL panels mavric Planars & Exotics 323 10th June 2010 04:01 AM
Loudness etc. of ESL panels jjbunn Planars & Exotics 10 13th November 2008 12:52 PM
Wraith ESL panels Sheriff Planars & Exotics 0 14th August 2004 06:37 PM
Copyright ©1999-2017 diyAudio
