Planars & Exotics ESL's, planars, and alternative technologies
Curved magnetostatic speaker
Old 8th February 2009, 04:09 PM   #21
båndsei is offline båndsei  Denmark
To bend it vertically is a mistake.There is loss of spl. and worse, loss off spl.in low freq.
Butt i vill still bend it horisontally .
[IMG]Click the image to open in full size.[/IMG]
Here is a picture of my setup
The sensivity of my planar speaker is higher than of the above.
Old 19th February 2009, 05:06 PM   #22
R. Jamm is offline R. Jamm  United States
Båndsei, you never gave a description of how these speakers sound? Do they give you a 3-d image? Are they holographic? What do they sound like? What speakers do/would you compare them to?
båndsei, do you make a kit of your project, so that other people can try them?
Old 20th February 2009, 05:59 PM   #23
I like the sound of ribbon speakers,but i want to make a "fullrange" speaker. It dont have to be high end just hifi.I wanted to elliminate the hot spot,and I did that.Now i will make a curved planarspeaker 20X115cm.[IMG]Click the image to open in full size.[/IMG]
Here is a picture of the steel konstruction.
Old 20th February 2009, 07:35 PM   #24
a.wayne is offline a.wayne  United States
Sin Bin
Bandsei ,
It's interesting to see your attempts , as I'm also playing around with a similar steel construction , the difference being , flat as oppose to curved and push pull for better full range operation ...
Old 28th February 2009, 06:16 PM   #25
jzagaja is offline jzagaja  Poland
Which glue is good for neos and aluminium? Last night I have used polyurethane with 10kg load. After 24 hours it's still wet! Anyone tried anaerobic glues?
Old 1st March 2009, 04:57 AM   #26
moray james is offline moray james  Canada
Default loctite black max....
best if you can abrade your neo magnet surface if they are plated.
http://www.henkelna.com/us/content_d...d_Silicone.pdf
moray james
Old 1st March 2009, 01:19 PM   #27
Here is a picture of my newest speaker.
And from behind.The subwoofer has a 15" passive radiator in the bottom,and it seems to be easier to match it with the panel as it is "tilted" 45`
It dosn`t go as deep as my first panel but deeper than my seccond one.This one is wider and not as curved.
I use iron and dont have to glue the magnets,and if i had to,i would`t use too strong glue becourse i will be able to remove them again.You could use silicone but not with accid, use one with alcohol regarding the aluminium.
Old 2nd March 2009, 05:27 AM   #28
Sin Bin
Bandsei,
You make hard work look easy .......... the metal work is fantastic looking .
Old 2nd March 2009, 03:16 PM   #29
I like the look of my newest planar ,and it is rather easy for me to make metalwork.I have the right tools.But i want it to go deeper,or maybe reduce the output in high frequenses.
Would it helpe to curve the membrane more, and wich radie would be the best??
The speakers from Martin Logan have curved membranes,what radius ,and how wide are they.
Old 2nd March 2009, 03:44 PM   #30
Sin Bin
Hello Bandsei,
Getting good bass out of your planer will take some work. Take a look at Magnapan l planers , i really can't see you getting good bass without going hybrid or to a large push/pull planer arrangement ..
Curved magnetostatic speakerHide this!Advertise here!
Curved sided speaker enclosures, why? cirrus18 Multi-Way 52 10th February 2009 04:26 PM
Copyright ©1999-2017 diyAudio
