PC Based Computer music servers, crossovers, and equalization
piCorePlayer = piCore Linux + Raspberry Pi + Squeezelite
Old 22nd December 2015, 09:44 PM   #21
Greg Erskine is offline Greg Erskine  Australia
Greg Erskine's Avatar
hi Russell.
Originally Posted by soundbyte View Post
What could be causing the drop outs as the dropouts do not occur when only one pi is working?
If you set the MAC address to the same on multiple players. LMS uses MAC address to uniquly identify players, or, general network problems. If you are using wifi things like the microwave and cause dropouts.
Thanks for having a look.
As alsaequal seems to be installed in the picoreplayer distribution natively I thought it may be of use to others who may need equalization.
Not sure if it can be implemented within picoreplayer though if alsaequal uses a web interface.
There seems to be some action regarding alsaequal. Some guys have it wokring on piCore. No promises though.
Thanks again for your efforts,
Thanks. It is good fun working with Steen and the other guys on this project.
regards
Greg Erskine
Old 22nd December 2015, 11:35 PM   #22
sckramer is offline sckramer  United States
sckramer's Avatar
Default turn off HDMI
In raspian you can turn off the HDMI port: /usr/bin/tvservice -o
and save ~30mA
is tvservice somewhere in picoreplayer?
Thanks!
Scott Kramer - AudioSystem - YouTube - Twitter
Old 23rd December 2015, 08:12 AM   #23
and save ~30mA
Thanks!
hi sckramer,
We haven't included tvservice in piCorePlayer by default, but if you install the piCore extension rpi-vc.tcz it is in there.
I haven't tested it.
regards
Greg Erskine
Old 23rd December 2015, 09:10 AM   #24
sckramer's Avatar
Slick extension system, didn't know about that...
It did seem to work:
tc@piCorePlayerZERO:/usr/local/bin$ sudo /usr/local/bin/tvservice -o
Powering off HDMI
tc@piCorePlayerZERO:/usr/local/bin$ sudo /usr/local/bin/tvservice -p
Powering on HDMI with preferred settings
Powering off HDMI
Old 23rd December 2015, 10:14 AM   #25
bambadoo is offline bambadoo  Norway
Thanks for the update.
ffmpeg version is bigger (12 MB) and allows in addition playback of ALAC and WMA via build in ffmpeg. In the Main page you can choose which version you will use.
I am unable to start squeezelite with ffmpeg version.
No matter what I try I get this:
Squeezelite is not running less>
With basic version it is ok however I have alot of alac files so.....
Old 23rd December 2015, 07:14 PM   #26
Powering off HDMI
Powering off HDMI
hi sckramer,
Thanks for reporting back.
A word of caution about adding piCore extensions. piCorePlayer is a very small image, about 70MB, so you can quickly fill up the free space. This free space is also used by insitu-upgrade. So you will need to increase the size of the partition at some time.
Also, when you do an upgrade, you will need to reinstall your extensions.
regards
Greg Erskine
Old 23rd December 2015, 07:23 PM   #27
hi bambadoo,
I just did the change to the ffmpeg squeezelite here and of course it worked properly.
Did squeezelite complete the download?
Did you run out of space?
Do you have jivelite loaded?
Did you do a FS resize?
A df at the Linux command prompt will tell all.
regards
Greg Erskine
Old 23rd December 2015, 08:45 PM   #28
Yes I believe so
Maybe?
No
No
tc@piCorePlayer:~$ df
Filesystem Size Used Available Use% Mounted on
tmpfs 833.2M 19.0M 814.2M 2% /
tmpfs 462.9M 0 462.9M 0% /dev/shm
/dev/mmcblk0p2 37.7M 29.7M 5.3M 85% /mnt/mmcblk0p2
/dev/loop0 128.0K 128.0K 0 100% /tmp/tcloop/dropbear
/dev/loop1 20.0K 20.0K 0 100% /tmp/tcloop/busybox-http d
/dev/loop2 256.0K 256.0K 0 100% /tmp/tcloop/alsa
/dev/loop3 896.0K 896.0K 0 100% /tmp/tcloop/alsa-config
/dev/loop4 128.0K 128.0K 0 100% /tmp/tcloop/libts
/dev/loop5 128.0K 128.0K 0 100% /tmp/tcloop/backlight-4. 1.12-piCore_v7+
/dev/loop6 128.0K 128.0K 0 100% /tmp/tcloop/touchscreen- 4.1.12-piCore_v7+
/dev/loop7 768.0K 768.0K 0 100% /tmp/tcloop/alsa-modules -4.1.12-piCore_v7+
/dev/loop8 384.0K 384.0K 0 100% /tmp/tcloop/libasound
/dev/loop9 256.0K 256.0K 0 100% /tmp/tcloop/ncurses
tc@piCorePlayer:~$
Old 23rd December 2015, 08:50 PM   #29
Thanks BTW
Did a FS resize and voila - it worked
tmpfs 833.2M 23.2M 810.0M 3% /
/dev/mmcblk0p2 14.2G 41.6M 13.7G 0% /mnt/mmcblk0p2
/dev/loop1 20.0K 20.0K 0 100% /tmp/tcloop/busybox-httpd
/dev/loop5 128.0K 128.0K 0 100% /tmp/tcloop/backlight-4.1.12-piCore_v7+
/dev/loop6 128.0K 128.0K 0 100% /tmp/tcloop/touchscreen-4.1.12-piCore_v7+
/dev/loop7 768.0K 768.0K 0 100% /tmp/tcloop/alsa-modules-4.1.12-piCore_v7+
Old 23rd December 2015, 09:22 PM   #30
Thanks BTW
Great news.
We will have to add more help info and checks for free space as we are finding more people wanting to add some extras and running out of space.
regards
Greg Erskine
piCorePlayer = piCore Linux + Raspberry Pi + SqueezeliteHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Another Raspberry Pi Radio rpi PC Based 17 17th June 2015 02:29 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
Raspberry Pi & accessories Nikitas Swap Meet 5 5th July 2013 11:47 AM
