| PC Based Computer music servers, crossovers, and equalization |
#11 |
#12 |
No, none of my DACs have an indicator. However, I think if either M2Tech driver was not bit perfect it would have been reported by now.
Hey, this just what I have heard, and many here will rubbish that because I don't have measurements to back it up.... from a quick web search: The M2Tech hiFace uses a proprietary driver to interact directly with a player in kernel streaming mode at a low level of CPU loading. It does so without any other drivers and allows for audio data to reach the peripheral easily and without any undesired changes to the data stream. That's the long way of saying that your computer will pass a bit-perfect 24/192 data stream without bogging down your machine or screwing with the sound. Fran
Visit www.tirnahifi.org!! |
#13 | |||
I do not think there could be a bit-perfection indicator. The check requires recording the stream with another device equipped with SPDIF input, and comparing with the original.
#14 |
Sorry now, don't mean to be prickly, just that I've seen so many threads go wrong: "If you can't measure it you're a fool and you must be crazy to be hearing a difference!!" To be honest I've much reduced the time I've spent here over the couple of months or so just because of this. Anyway, look rant over, don't mean to go so off topic.....
Anyway, back on topic.... nope, I don't have the facility to record via SPDIF, which is a pity as it would answer the question alright. Can the OP do it I wonder? Take your point RE: the marketing speak - I searched for a few minutes and that was the first thing that came up that mentioned M2Tech and drivers being bit perfect. Might need to search harder, although surely someone out there has done this work already! Fran
#15 |
OFC it is bit-perfect. It has been tested numerous times.
The latest reference I can remember is a detailed review in AVMentor, a greek website, with measurements and stuff (very good site btw, but it's going to be all greek to you!)... Here is the page with the measurements: Click You'll be able to understand the graphs, at the very least but Google Translate could help with the rest. |
#16 |
#17 |
I haven't heard any significant sound difference between the drivers, tbh, but I've only listened to it on my desktop setup.
The main difference is that with one driver set you play up to 24/192 while with the alternative drivers allow up to 32/384 through the USB. |
#18 |
My files are 16/44
#19 |
As we don't know the internal operation of m2tech's proprietary platform, everything is possible. Drivers could affect jitter or other aspects of the performance that we are unaware of.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones |
| FS M2Tech Hi-Face EVO + other parts | sureshm | Swap Meet | 9 | 24th November 2011 07:10 PM |
| in-room frequency response & transient response | MCPete | Multi-Way | 1 | 8th October 2011 06:31 AM |
| strange port frequency response | jrwone0 | Multi-Way | 1 | 3rd March 2009 10:18 PM |
| Strange dip in bass reflex response | AntM | Multi-Way | 10 | 13th June 2006 08:02 PM |
| Doubts on Phase Response and Frequency Response | dumrum | Multi-Way | 11 | 5th April 2004 10:39 AM |
| Page generated in 0.10307 seconds (79.52% PHP - 20.48% MySQL) with 11 queries |
