| PC Based Computer music servers, crossovers, and equalization |
#41 | |
However I don’t know how it communicates through USB, it comes with his own drivers from M-Audio. It works full duplex only up to 24bits / 48 kHz and one way at 24bits / 96 kHz. |
#42 | ||
#43 | |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
R |
#44 |
HD (24 bits, high sample rates) starts to be available, (there is magnatune.com, musicgiants that I know of), and others start to offer 16-44 FLAC at decent prices too... we're at the beginning of this.
#45 | |||||
R |
#46 | |
R |
#47 |
Right now I'm wondering wether to implement oversampling/crossover in the FPGA or with CUDA. Now that the new GPUs support double precision, it is so tempting... crossover in the FPGA would be IIR 'cause not enough memory.
Hey guys, make me a crazy wishlist, what would you like in a PC-based DAC ? |
#48 | |
i'll stick with sse4 or anything supported by core 2 duos. on top of my wishlist woudl be a lossless volume control...
The response of the inner ear extends to at least 200khz - Dr W. Tempest |
#49 |
For the volume control I'd like to try some LDR a la "Lightspeed" controlled by the computer (ie the volume slider), so things like ReplayGain work. We'll see if it sounds better than digital volume control...
I've been looking around for GPUs and all the new ones which support double precision have huge fans. OK, so I'll put FIR in the FPGA then. |
#50 |
i can only agree to Russ, use COMP + CPLAY with XP follow CICs advise on how to setup the PC and buy a ESI Juli Soundcard which gives you I2S without soldering any SMD stuff and connect it to the twisted pears Sabre DAC.
You can even directly drop the Twisted Pears Dac with a 20 pin connector to the Juli. This sounds better than most transport and DAC combos you can buy. Just try it, it costs less than most players out there, you will be surprised. just my two cents. |
| Page generated in 0.13807 seconds (81.47% PHP - 18.53% MySQL) with 10 queries |
