Hi Guys,
I am a complete newcomer to this hobby but would desperately like to build a First Watt F1 for my AKG K1000 headphones. Can somebody tell me how I could go about aquiring PCB's and a parts list for this? I know that a circuit diagram is available for this but how do I go from there? Any help would be appreciated!! |
#2 |
Account Disabled
Ah . . . AKG K1000 . . .
I have tried it on a big tube amplifier . . . I think F1 must be good for it. By the way, I do not remember whether someone has offered any diy F1 PCB. P2p using perf. board could be an easy alternative . . . Good luck. jh |
#3 |
Mystical traveller,
i'm also contemplating a First Watt DIY production for the K1000. Not sure which F anymore as NP is pumping out products faster than i can study them. (i strongly believe NP is doing this on purpose, driving copycats mad once and for all) With Lovoltech devices distribution well underway i was more thinking of a JFET version for the AKG, and hoping there'd be a GB design coming. Sort of like figured that to be the last headphone amplifier i will construct, the only unreliable parameter being Master Pass.
Not so much,.......if it says "ZM" in the corner. |
#4 |
I think the F2 is meant to be quite a good match with the AKG K1000's as well. Anybody doing a board for that? Either of the F1 or F2 will do for me!!
#5 | |
for PCB design have a look at: http://www.acaudio.de/F1_200.pdf The original service manual is at www.firstwatt.com available. Good luck Adam
http://www.acaudio.de |
#6 |
I have made PCB from schematic. Both Power Supply and Amp Boards are ready. There is difference in size & components size (resistors / Pot ) e-mail me, for further details, I will mail you pdf or PS Board and AMP board. (Attached is image of AMP Board) |
#7 |
Final Stage of F1 Amp
Now that I have a working F1 Amplifier.... Observed the following... (I did not put Heat sink.) MOSFET becomes Very very Hot.. (Q3 and Q4 Smokes with out heat sink) Thick Heat sink with silicon paste and insulation is required. Quality of sound is very good.. ! Instead of ztx550, BC557 is used. |
#8 |
I have got F1 PCB's in stock now.. I can mail you actual images, costing etc. image file is 2.5MB PCB are FR-4 2.4mm 1/1 OZ $36 for Stereo Set PCB (Two Amp PCB L & R, and one Power PCB) $20 onwards , shipping via EMS Speed post. additional PCB's $13 each (Add 2% on total value Paypal / Bank charges) Thanks Suds |
#9 |
After I learned about copyright issues, I modified board layouts. Added copyright and original Author names. This board uses Vertical MOSFET, attached is file (pdf) containing layout image. Authors, please comment on this.. ! (Hope I will be exempted from Moderation after this.) thanks suds |
#10 |
The one and only
As an example to future efforts, I would prefer to
see something like "F1 DIY CLONE" The copyright notice is not appropriate, as this artwork is not mine, it's yours.
| First Watt F1 Pcb | menekken | Pass Labs | 20 | 31st January 2009 04:09 PM |
| first watt f4 help me!!!! | mosfet1 | Pass Labs | 2 | 18th May 2008 06:44 AM |
| First Watt F1 need HELP! | Simon CHAN | Pass Labs | 1 | 4th December 2006 07:06 AM |
| First Watt F4 ,F5, F6, F7, F8 ? | MikeW | Pass Labs | 9 | 9th November 2006 07:16 PM |
