Hi all,
i hope that there is nothing about power supplies with CAR- batteries or accus. I think at a 12, 0, 12 volt psu for ALEPH X. i searched the forums, but found nothing. I think that a big improvement of sound can be done with battery psu. Even more than with super expensive capacitors like RUBICON BLACK GATES. Since i am no electronic expert i ask you all for schematics and suggestions. Why do one need in an accu psu such big capacitance? When the accus are fully loaded, can one connect to an amp direct to the accu ore are the capacitors required anyway.... Regards, Ralf |
#2 |
Is it wise to want to feed an amplifier that draws at least 4
amperes all the time with batteries? You will have a lot of work when you need to recharge them every few hours of playtime. Even if you decided to come up with a circuit that will handle the charge job, (which is not a trivial task), you will have to ask yourself if it is worth all the extra trouble/expenses. Especcially if you know that there is a real good alternative in the form of an isolation transformer. If you are going to use batteries I would shure like to read your experiences with them. Regards. |
#3 |
On Hiatus
Can make a VERY good Source of Current
for an AUDIO amplifier. It is usual to eastimate, that you can USE half of the nominal VAh. So for a 60VAh, you can use 30VAh, before reload. It is fully possible to RUN some time during day. And RELOAD, While you are sleeping at night. Say you have 2 amps, draws 2x2A= 4A Your battery is rated 60VAh, use half 30VAh 30 Vah is consumed in: 30VAh/4A= 7,5 hours So if you drive 7,5 Hours (use timer ON/OFF) You have 16,5 hours for to Reload, each night No 50 Hz ripple from batteries, No Transformator No Rectifier-bridgde No disturbance from Mains crap There are millions of persons using this kinda systems. The Car-Stereo People. They are the real Experts on HIFI. they do not discuss mains-hum, and a lot of things that we have to cope with |
#4 |
On Hiatus
of AMPs for Battery Operation
All smart DiyAudio designers and Nelson, too if he likes to compete with his own other designs for MAIN AC Current |
#5 |
For Yachts you can buy extra large 24 V batteries (and a generator
Is that all there is? |
#6 |
ralf: The N.E.W DCA-33 (by Nirvana Engineering Works, USA, now defunct) is a 33w/ch Class A, battery powered pure d.c amplifier. It is supposedly based on the Nelson Pass A40 with a d.c power supply added. There is also a bigger N.E.W DCA-66 amplifier.
The DCA-33 is a beautiful, sweet sounding, high current, 'doubling' amp that will run continuously for 20hrs on it's 4 X 17AmpHr Panasonic batteries. The whole system is self-charging and fuss-free with the batteries lasting 3-4yrs before requiring replacement. However, I'm not entirely sure that the benefits of pure d.c battery power are really worthwhile? I have not heard the NP A40 so cannot say the DCA-33 is far superior to it with it's battery supply. However, I have compared the Pass Aleph 3 with the N.E.W, and the little Pass amp is sweeter in the treble (although it is a close thing overall). The N.E.W however, delivers more current and outdrives the Pass. Surprisingly in one comparison, the N.E.W almost kept up with a Krell KAS200 for outright drive! Although the Krell did play louder, it definately did not have the finesse of the little battery powered N.E.W . Also IMHO, as far as solid state amps go, the Belcanto EVo200.2 amplifier with it's Tripath Class-T digital circuitry is better than all of the above. Regards, Steve M. PS: Before you ask, I do not have the circuit diagram for the N.E.W amps. |
#7 | |
On Hiatus
#8 |
On Hiatus
#9 |
halojoy: Please advise where you got the 'quote' for the DC-33 amp. I wouldn't mind reading it in it's entirety.
Thanks, Steve M. |
#10 |
On Hiatus
Steve
That was all the reviewer, Terry Soohoo, wrote. Very little I found on the web. Just about all is these links at AudioWeb. One review. And some previous "for sale". Simular difficulty to find Nirvana at the web. Just an adress in Santa Fe. http://www.audioweb.com/Review/Revie...&revieworder=1 http://www.audioweb.com/Directory/Mo...?modelid=10216 http://www.audioweb.com/Directory/Di...?companyid=457 |
| Accu supply for preamp | hahfran | Solid State | 1 | 2nd January 2008 04:53 AM |
| DAC Battery power supply | dzkh63 | Digital Source | 2 | 25th April 2007 02:40 PM |
| Need power supply to simulate AAA battery | dragonrand | Power Supplies | 2 | 15th December 2005 10:09 PM |
| Battery Power Supply | PH | Analogue Source | 4 | 3rd May 2005 01:03 PM |
| Battery power supply for gc | dreaded 42 | Chip Amps | 4 | 21st December 2003 06:36 PM |
| Page generated in 0.12661 seconds (86.50% PHP - 13.50% MySQL) with 11 queries |
