Old 19th December 2005, 06:28 AM   #1
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
Default Treshold Stasis S300 Vs Aleph 30
I am happy owner of Treshold S300. I compared it to my recently finished Aleph 30 and in my opinion Aleph is better. Highs are cleaner and more open. I am thinking to use Stasis case and to house inside Aleph.
I am just wondering if heatsinking should be enough for Aleph. The case and the heatsinks are masive and heatsinks are roughly 12" x 8" x 3" on both sides. I am afraid to gut everything out and to realise that it wouldn't work, so please share your opinion.
AR2
Old 19th December 2005, 12:12 PM   #2
mpmarino's Avatar
If those fins are really ~3 inches deep I'm inclined to think that they will work fine. As a contigency plan you could always bolt additional sinks on the inside of there is room. I 'think' I have seen Nelson do that on his new firstwatt chassis' too....could be mistaken though.
Crazy Yankee.
Old 19th December 2005, 02:31 PM   #3
Master Burner
AR2's Avatar
I like that idea a lot.
Stasis is built so well and there is a lots of room inside.
I just love these big amps, and the way how they are built. That monster will never stop working. I guarantee that few milleniums ahad people will be looking and listening Pass amps in order to learn about our civilisation.
Old 19th December 2005, 04:38 PM   #4
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
just use your Treshold ,say,for woofers or something
or sell it ,then use money for your project
I think that is almost sacrilege to dismantle it ;
hehe-just few thoughts-this is your amp.....
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 19th December 2005, 07:09 PM   #5
Master Burner
AR2's Avatar
I was thinking about it, but it is not powerfull enough for my woofers. I feel kind of same - keep it, but again it will be just sitting there. Case is so nice that I just canno't resist in using it. I am using my 2A3 aps for mids so it doesn't work there ether. It is easy to carefully remove stuff and to preserve which I am planning to do.
Sale is not an option.
Choky posetio sam tvoj web site i odusevio se opisom Iskrinih uredjaja. Ja sam takodje imao neko od tih pojacala pre dvadestetak godina.
Pozdrav
AR2
Old 19th December 2005, 09:31 PM   #6
Zen Mod's Avatar
Pozdrav
AR2
hehe-then replace your woofers
I repair electronic gadgets for living,and doing this ,I just stashed enough decent or just nice apparatus to make at least one decent system for every room in few houses .....
but-I have not enough time to finish that ,just soo called,project -not to mention that I can't split my self in so many rooms
anyway-if your Treshold serves you more than well-just find some decent speaks and put it ,say,in bedroom or anywhere you can think...
who knows when you'll decide to use it more seriously....
tnx to kind words for my site's content
I'm glad that world is so small
kako bi mi ono rekli :"govori srpski (hrvatski ,bosanski-nije bitno koji)
da te ceo svet razume........"
you always have one (above anything else) -SMART solution -just send that old Treshold s*it to me for safe disposall .....
ps-I just checked your home page
nice ,too
now I can think few more places where you can use that Treshold properly
some things are just waste to sell
proper camera,for instance-even if we have more modern gadgets ,appropriate for this days use,I don't know nobody sane who will sell Laica or Olympus Pen or some simillar piece of jewellry.....
cheers-wherever you are
Old 23rd December 2005, 06:34 AM   #7
Master Burner
AR2's Avatar
On Stasis, transistors are mounted on 1/2 inch aluminum that is attached to heatsink. Both surfaces are covered with some clear gel. Obviously this is used to improve heat trasfer. Does anyone knows what kind of gel is this? I haven't seen this kind of gel, just a white silicon grease.
Ar2
Old 23rd December 2005, 09:53 PM   #8
Zen Mod's Avatar
Ar2
I didn't see thermal grease in clear "collor" ;
it's always whitish or,recently, in silver .
but-I can say that I hear few old techs that they used vazeline in old days for same purpose.
only Master can answer that fer sure
Old 26th December 2005, 04:51 PM   #9
Master Burner
AR2's Avatar
Default Staleph 305
Done!!!
I am done with with my Aleph 30. Acctually it is crossover between Aleph 30 and Aleph 5. My rail voltage is 30V which falls right between Aleph 30 and Aleph 5. Since it is housed in Stasis case I call it Staleph 305.
Stasis was simply bult on block of 1/2 inch aluminum, with another aluminum block over it that holds all electronics and connectors, as well as holds heat sinks. I kept everything intact by removing that block and replaced it with another 1/2 inch aluminum block. Than I installed my output stages on that. I replaced original PS with my Piltron transformers two 400VA; 2x22V each.
Old 26th December 2005, 05:05 PM   #10
Master Burner
AR2's Avatar
Boards are Mini Aleph originaly designed by GRollins and made by Brian GT, parts are from JLeaman, and mosfets from Anthony - Colomb ( ), and Aleph and Stasis are designed by Mr. Nelson Pass. Thank you all - this is real collaborative project.
Here are PS boards - all together 12 x 22,000 uF - or 264,000 uF.
NAD s300 HFERRAO Parts 0 10th May 2009 11:44 PM
NAD S300 int amp problem hifienthusiast Solid State 9 18th March 2009 04:10 AM
Nad S300 DFroehlich Swap Meet 1 7th April 2008 03:51 AM
Best bias for 400a/S300? centaurus3200 Pass Labs 2 20th April 2007 11:12 PM
Theshold S300 Amp Gwiesner Parts 0 17th November 2006 06:51 PM
Page generated in 0.13182 seconds (76.36% PHP - 23.64% MySQL) with 11 queries
