choky said:ps. just imagine number of emails to NP from this DIY bunch every day....................
My email was not sent from this DIY forum...
from personal experience,I know that NP don't make difference between mail addys,domains ,are you known on DIY or not.....
just a thought-he recently changed ISP,mebbe some sort of spam filter was in action (it happens all the time);
or-if you examine his post again (and that is often needed with NP
dunno for sure.....
I don't currently employ a spam filter, each piece of mail is
actually glanced at, and since Network Solutions is now the
host, I don't expect future difficulties.
Nelson Pass said:I don't currently employ a spam filter, each piece of mail is
woa! (blue car!) 😉
so-even I can send you personal e-mail ,with another one brilliant idea
nah....
forum is good enough 😉
We talking about SE JFET amp -
I had (and still have) a few ideas (not only for jfet amp) ...
but...
It doesn't matter anymore...
F3
After the Ver 8 Zen light, I started on a Ver 9 and before I could finish, the Firstwatt JFET F3 amp was released so i thought I would wait until Mr. Pass published the schematic. Here are some tips that might be useful to others building the F3. I used the Ver 9 PD boards for this project and modified them for the F3.
The JFETs were measured as per the Ver 9 article. The JFETS I used measured 1.02 volts across the 1 ohm source resistor. I adjusted P1 to get half the supply at the output and 2.5 volts Drain to Source on the JFET. Then I hooked up the distortion meter and adjusted the source resistor for the minimum distortion. The source resistor turned out to be about 1 ohm. When I tried to adjust for half the supply voltage at the output I couldn't get there. I was short a couple of volts. I changed R12, 10K to 15K and put in a 10K pot. at P1. Now I could make the adjustment.
After adjusments on P1 and the Aleph CCS P2, I measured .0126% at 1 watt @1KHz. I ended up with 1.5 VDS on the JFET. At .1 watt the distortion was .003% just what Mr. Pass had published.
Listening comes after I get the other board changed to the new values. Oh who am I kidding, I will have to listen to just one channel. I can't wait for the other channel!
Thanks Nelson for the great articles. With out them I would not have built so many amps.
First Pass DIY amp built in 1990.
BDP
BDP
Re F3
I took a distortion measurement with a source resistor selected from the graph Mr Pass had for Vgs vs source resistance. The JFETS that measured 1.02 volts in the test setup would require a slightly less than 1.5 ohm source resistor for R5, (R3 for Ver 9). I used a 1.5 ohm. When the output voltage was adjusted for half the supply the VDS of the JFET was 2.46 volts and the 1 watt distortion measured .037%, not too bad.
Anyone else building the F3? Besides Mr Pass!
- Pass JFET Amp- I'm making one!
