New Aleph Mini PCB GB - Page 139 - diyAudio
Old 13th November 2010, 12:37 AM   #1381
RIP
Yes, that's correct.
Old 13th November 2010, 01:13 AM   #1382
ra7 is offline ra7  United States
I don't know if this has been asked before, but can you use these boards for an aleph J?
The circuit is quite similar. Papa recently provided direction towards using the new
Semisouth JFETs in an Aleph J and I was thinking of giving it a try.
Old 13th November 2010, 02:43 AM   #1383
troystg is offline troystg  United States
troystg's Avatar
Originally Posted by woodturner-fran View Post
Sorry guys, I just need to check something.
Using the amp single ended on the brianGT boards. Ground the neg input and use GND and + right?
Fran
Yep.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 13th November 2010, 11:43 AM   #1384
RIP
Sure. Just a little leg twisting for the front end semiconductors, and a few jumpers and you have a J. Then you can sub the SemiSouths for the bottom signal fets. You can also disable the Aleph CS circuitry to make a pseudo F3 with dual rails if you would want to try that also.
Old 14th November 2010, 10:07 PM   #1385
Thanks for the help guys....
Old 21st November 2010, 02:03 PM   #1386
Default It's working ;)
Hi folks, first picture of my working MiniA
It sounds very nice right now, no hum, no buzz, only music !!!
Ok, I need a good enclosure
I let it burn in this configuration.
You know what ? I feel good !
Many thanks to all of you, Mr Nelson PASS, BrianGT and to other guys who make it real
Old 23rd November 2010, 02:57 AM   #1387
Anchan is offline Anchan  United States
Default Heatsinks
Glad you got it working. Could you tell me the size of those heatsinks, and approximately how warm they are getting. (Finger test is accurate enough).
Could you describe the sound in two or three sentences?
Old 23rd November 2010, 07:30 PM   #1388
Thanks Anchan
The heatsinks are oversized 20x10x8cm (L/H/W), just a little bit hot.
I can let my fingers on without hurt, very low temp.
About the sound, very detailed, deep bass, everything is much more "clear".
Running config : UGS preamp / MiniA / Opus DAC and USB, balanced inputs except USB. Previously I was using only a UCD180ST.
As I've got a DCX2496, I'll bi-amp my system, UcD will be dedicated for bass only.
Very rich sound, much more "life" in the speakers, more details in the sound, yes "rich" sensations.
Sorry for my bad English.
Cheers
All components are stock values, but all of them are matched...
Old 25th November 2010, 04:41 AM   #1389
stealth please, for aleph 5 with briangt board, on his board where are going the parts i need help ihave the new boards and parts i want a make sure where they go on briangt boards thank you in advance pierre
Old 25th November 2010, 04:01 PM   #1390
Stealth is offline Stealth  Slovakia
Stealth's Avatar
Pierre,
if You have briangt boards, see the partslist from attachment below.
However 680pF (c6 in original) not be used, it´s the same as orig. NP aleph5 scheme.
Regards denis
(sorry for my bad english here)
mini-aleph versus aleph-3 rmgvs Pass Labs 7 4th February 2010 04:18 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 04:58 AM
Aleph Mini / Aleph 3 PCB ready (?) croccodillo Pass Labs 5 27th July 2009 02:51 PM
Difference between Aleph J and Aleph J Mini ppmmcc Pass Labs 5 17th May 2008 07:10 PM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 07:29 PM
Copyright ©1999-2017 diyAudio
