Bride of Zen, Bride of Son of Zen
attenuation at the output:
e. g. paralell a 10k res to your 10k pot - this gives you a "5k pot load" similar to the original schematic and decreases the output signal.
r3 100k is only for sim purposes (e. g. input impedance of an amp.......)
annother option......if you build in a 820 ohm res instead the 1k drain res (or
paralell a 4,7k res to the 1k ) the gain will decrease.......(around 4 x)
.....and at last.......lower r12 (10k) to 4,7k or so..... attenuates the signal a bit.......this is a little bit crude, but it helps.
(or you try out to change r3 at the output with 4.7k .......)
.......yes, the current is low.....less heat.
the boz has only a few parts to measure, so check every res (ohm) with your dmm......
is the 100uF (c102) electrolytic cap built in the right way?
if they all are correct, search for a bad soldering point/lost connection.
......and the 1uF input cap not to forget......
I'll check. Now I have p102 on max and bias is 2,8v if plugged in rca with CD but wihout rca it's 5,0v. Second channel still 5,6v. Caps are in good direction.
I found- R105 is ca. 70k but I'm 100 % sure that it was correct 100k
