.......yes, the current is low.....less heat.
the boz has only a few parts to measure, so check every res (ohm) with your dmm......
is the 100uF (c102) electrolytic cap built in the right way?
if they all are correct, search for a bad soldering point/lost connection.
......and the 1uF input cap not to forget......
I have replaced the damaged jantzen cap with a cheap replacement and now all voltage values are stable.I am concerned about that problem with cap-what was the cause of damage becouse everthing was ok
- Bride of Zen, Bride of Son of Zen
