Caddock Resistors
Mega-Amp,
Have you considered using Caddock resistors? You can buy them in pretty high wattages and would be much easier to mount. (1 less screw to drill and tap per resistor since the Caddocks are TO type).
A potential problems I find with high wattage SoZ is the heat from the mosfets. In the area of 50 watt output, I highly recommend that you spread the heat over more than 1 mosfet.
I still have my big SoZ but don't use it much. Not after i've finished my Twin Zen v4s
BQ
Mega-Amp,
BQ
Your right, my original plan with the SOZ was to use this modified schematic. since i already purchased all the resistors i'm all set I believe, but i need to buy a few more to implement the modified schematic. The plan is for 35-40 watts. BTW, your SOZ is an amazing monster.
