Dear Mr Pass
as a newbie to audio, and having read some of your articles on the PassDIY page, i would just like to say thank you for writing such insightful articles...i do have a small question though...i was just reading the article on the A75, and i was wondering what this folded cascode arrangement is...i am referring to the series combination of cap and resistor at the tails of the dual diff pairs...and also, how do you determine the gain that is required? |
#2 |
The one and only
You can set up the A75 for a conventional voltage gain
stage on the second stage, or you can set it up as a folded cascode, loosely defined as a cascode circuit which also functions as a level shifter. You can find out more from the www.passdiy.com (or) www.passlabs.com article from Audio magazine on cascoding. In any case, the folded cascode has a lot less open loop gain than the conventional common-source arrangement, but is very fast and stable. The output current variation is equal to the output current variation of the diff pair, so in that sense you can think of it as a current mirror with unity gain. |
#3 |
thank you very much....i will definately have a read...thank you writing your articles in such a way that no so smarts like me can understand
#4 |
diyAudio Moderator Emeritus
I tried to understand folded cascode, if the differential is running at very low current (Mr.Pass uses it at high differential current). If the differential is running at 2mA ccs (1mA each leg at steady state), I assume each leg is capable of 0-2mA (if the other differential leg is on or off).
Putting folded cascode (set the bias about 10mA), that means the level shifter stage can be 8-10mA. The difference is the same as in the differential, 0-2mA. What is really important in the level shifter stage, is it the bias (big enough, 10mA) or the difference current (only 0-2mA). In the ordinary common emitor VAS, the swing can be anywhere from 0-bias, but in this folded cascode the swing is limited only to 0-differential current. If the bias is high enough, but the swing is very little (the same as in differential) will it suffice to drive the current amp stage? |
#5 |
The one and only
You can set the level shifter at any bias current you want, but
if you set it up to deliver AC than the output of the diff pair, it becomes a real gain stage. I have a current working definition of what constitutes a gain stage - it is a stage with voltage or current gain, and I don't count cascodes with no current gain. |
#6 | ||
Hi, Mr.Pass,
Why do people like to bias the VAS as big as possible, if less than that is enough? (in ordinary 3 stage configuration, not folded cascode configuration) I follow the thread of x100 backengineered. Personally, I suspect that the bias in the differential =50mA dont have to be the same value in the folded cascode =also 50mA. They can be made different. But I dont see your comment on this. Are you using the same value or different value for differential and folded cascode? Quote:
This opamp design is made by Sonnya. J1-4 is the output to the current stage. I see it as very clever opamp design. I made comment to this (in other thread) as a "SINGLE STAGE OPAMP", as I see it only have gain from differential. The folded cascode and current mirror dont have gain. But Elso Kwak said "I think most of the gain comes from the current mirror loading the folded cascode....." What makes him see the cct that way? |
#7 |
The one and only
"I see folded cascode has perspective of current swing transfer. If we use folded cascode, is it true that what is important for driving the next stage (in my example of 2mA diff and 10mA folded cascode)"
Yes, the swing of the diff pair is that will determine the output of the cascode, since the cascode has no current gain. "The 10mA steady bias wont matter so much. If it is the 2ma swing who drive the next stage, how much mA swing will be sufficient?" It is always good to bias a folded cascode transistor at somewhat higher than the swing of the diff pair, to prevent it from contributing nonlinearity. 2 mA from the diff pair is not very much, but that whether it's enough depends on the load. I like to use higher figures when using folded cascode in power amps. "Why do people like to bias the VAS as big as possible, if less than that is enough? (in ordinary 3 stage configuration, not folded cascode configuration): High bias on the VAS improves its linearity, and provides more current to drive the load. "I follow the thread of x100 backengineered. Personally, I suspect that the bias in the differential =50mA dont have to be the same value in the folded cascode =also 50mA. They can be made different. But I dont see your comment on this. Are you using the same value or different value for differential and folded cascode?" See above "But Elso Kwak said "I think most of the gain comes from the current mirror loading the folded cascode....." What makes him see the cct that way?" If the output of the current mirror is loaded with high impedance, then it will deliver voltage gain, even if it is set for unity current gain.
#8 | ||
Hi, Mr. Pass,
So, current mirror can make voltage gain, even if the current gain is 1. If the output is between collectors (like the sch of Sonnya), I think even if the current swing is as low as 0.01mA, it should be able to have full voltage swing between rails, the problem is how much mA is enough for driving the next stage (like my question above) So my view of Sonnya's opamps is wrong. It is true that it has no current gain, but it does make voltage gain. How to calculate voltage gain in this folded cascode design? |
#9 |
The one and only
The diagram above would not appear to have a lot of gain
as there is quite a bit of resistive degeneration on each stage, but this all depends on the load, which is not part of the schematic. |
#10 |
Hi, Mr.Pass,
From Sonnya's design and your tutorial about low gain and folded cascode, I came up with this design. I wanted to use single differential, but I also likes pushpull VAS. In this design I could use folded cascode, but I choose current mirrors. The differential is working at low bias, 2mA, but from your opinion, the output stage must have more current. So in the final current mirror, I try to get different Re, 2K and 200ohm, so the final stage is bias at 10mA. What is the good and bad thing about this design? Will the modified final current mirror gives full swing of 10mA (will it able to drive another current stage?) Since there is somekind of current gain in the current mirror, will this still classified as low gain design (compared to ordinary 3 stage design)? |
| To Low Pass Or Not To Lowpass...That Is The Question | CarlosT | Full Range | 2 | 18th December 2006 11:45 AM |
| Question for Mr.Pass | Metric | Pass Labs | 5 | 27th May 2005 09:17 PM |
| Question to Mr. Pass | Metric | Pass Labs | 7 | 19th April 2005 10:13 PM |
| Question for the One and Only. (Mr. Pass) | K-amps | Pass Labs | 7 | 4th February 2004 06:35 PM |
| A Question for Mr. Pass (and all..) | W.O.L.F. | Pass Labs | 4 | 12th March 2003 12:59 AM |
| Page generated in 0.11934 seconds (87.14% PHP - 12.86% MySQL) with 11 queries |
