Old 25th February 2004, 02:18 PM   #1
www.audiohobby.com
Default Pass Patent 5,343,166
Mr. Pass: In figure 4 of this patent, which current source is the high current one? Could the alternative bias path be a resistor (or a lightbulb) or is that too low impedance?
Thanks for your time!
Mike
Old 25th February 2004, 03:28 PM   #2
www.audiohobby.com
I'm still trying to work some lightbulbs into that circlotron. This could be the trick...
Old 25th February 2004, 07:00 PM   #3
The one and only
Nelson Pass's Avatar
Default Re: Pass Patent 5,343,166
1) I don't remember, and my only copy of the full patent is
in a frame.
2) Yes, but a CCS is better and more efficient, properly done.
Old 25th February 2004, 09:34 PM   #4
The way I read it, the current above and below the output (95 in Fig. 4) must balance at zero signal input. With that in mind, the lower current source (101) must carry current sufficient to match the upper current source (97), plus a smaller amount for the cascode device (91).
Assuming that I've got all that right, 101 is the larger current source, but not necessarily by a whole lot.
There's still a net savings in dissipation, however, because the heavy current in the circuit above the output line (95) isn't covering the full rail voltage.
Asymmetrical rails, anyone? That could lead in a whole 'nother direction. Might be fun.
A low Z path (i.e. a light bulb) around the output MOSFET (87) would effectively short--or at least draw off a large portion of--the intended output.
Light bulbs in a Circlotron? How about as emitter/Source/cathode resistors?
Grey
Old 26th February 2004, 08:17 PM   #5
www.audiohobby.com
Thank you both.
I had always (wrongly) assumed this patent was related to the Aleph 0.
Looking at Aleph 0 schematic:
Could the Aleph 0 be thought of like a power op amp with a big pull-down resistor? If so, I wonder if this would work with something like ZV5? Just pondering out loud. Thanks again.
Mike
Old 26th February 2004, 11:22 PM   #6
Ahem...
Who says this patent couldn't relate to Alephs?
Grey
Old 26th February 2004, 11:58 PM   #7
www.audiohobby.com
Hi Grey:
I read in an NP post somewhere that he's never employed this patent in a commercial product. I took that to mean that it is not employed in the A0.
...now how about my giant pulldown resitor idea (analogy)?
Old 27th February 2004, 12:51 AM   #8
diyAudio Moderator Emeritus
Would it be the device 87 is 2SK1380 and the device 97 is the 7A Tango transformer?
Old 27th February 2004, 01:25 AM   #9
Hey that schematic looks like some of the old SAE's that I used to repair......! I think this guy is in the wrong forum...thats definately not an Aleph... Looks more like a vintage Bongornio to me(spelling?).
Old 27th February 2004, 01:33 AM   #10
Magura is offline Magura  Denmark
Magura's Avatar
Im glad to hear that this schematic dosnt have anything to do with Aleph, cause i spent quite a bit of time trying to figure where the resemblence were with no succes
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Texas Instruments licenses Pass patent Nelson Pass Pass Labs 40 15th May 2011 01:59 AM
Has the Pass Labs patent for Aleph 5 expired? Paulcocom Pass Labs 20 4th May 2011 11:40 AM
Patent? What patent? Taterworks Subwoofers 1 28th January 2009 07:55 AM
Patent #4,107,619 lumanauw Pass Labs 17 19th August 2005 04:26 PM
Another Nelson Pass Patent lumanauw Pass Labs 5 15th November 2004 10:15 AM
Page generated in 0.11594 seconds (81.00% PHP - 19.00% MySQL) with 11 queries
