Beginner to build an Aleph30 needs some help - Page 3 - diyAudio
Old 20th January 2014, 07:09 PM   #21
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
R12 - yes
but value of R12 is transposing further exactly voltage resulted across R23-R26
so - do not alter their value unless you know what you're doing
tip - even if you can't grasp what's going on - just print all original Aleph schematics and study them
one of them will suit your needs , then follow it blindly
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 20th January 2014, 07:12 PM   #22
6L6 is offline 6L6  United States
6L6's Avatar
Originally Posted by cowneko View Post
For the heatsinks, here the big babies
You are building a 6- device Aleph with 32V rails.
Your heatsinks are not all that big...
But they will work.
Probably Aleph 5 or 2.
Old 20th January 2014, 07:16 PM   #23
BobEllis's Avatar
The sense resistor value fits into the equation, but we usually play with the smaller cheaper ones. The gain is set by the ratios of R20 to R12 and R23-26 net to R35, 37, 39 net parallel. With the sense resistors equal to half the parallel source resistors and R20= R12 we get ~50% AC gain, IIRC.
Yeah, those heat sinks are sissy sinks for the build you planned. They probably will be awful hot at 180W. Cut back to 4 pairs. Looks like store cases packaging. The 3 pair 30V rail amp needs the 5U case.
Old 20th January 2014, 07:27 PM   #24
cowneko is offline cowneko  France
Maybe the pictures doesn't do those heatsinks justice, but they are 5U heatsinks (300mmx210mmx40mm) given for 0.2C°/W
I just find them huge cause I never came across heatsinks those big
Old 20th January 2014, 07:29 PM   #25
Zen Mod's Avatar
4U is good up to 100W diss per side , confirmed in real life ( though , not in Bombay )
5U is for not much more ..... say 125W max
Old 20th January 2014, 07:30 PM   #26
6L6's Avatar
You might need a fan.
No worries, moving a little air makes a big difference.
Old 20th January 2014, 08:35 PM   #27
Well, I have to think of something for the cooling then..... maybe a 120mm bequiet computer fan (15db at 12V)
be quiet! Silent PSU & Cooling for your PC
Witch will be placed on the top plate of the amp in blowing mode (outside air pumped inside the chassis
with a little 30VA 2x15v (for the Speaker protections) and 1x9v (for the fan)
Transformateurs torique - Transformateur torique 30VA 2x15V + 1x09v
plus a little regulator psu to feed the fan with DC voltage
Alimentation linéaires - AMC - kit Alimentation régulée 1.5/30VDC 3A LM1085
I will make a BOM for the amp, I hope you'll be able to tell me if there's something odd with it
Old 20th January 2014, 08:57 PM   #28
BobEllis's Avatar
Save yourself a transformer and the fan controller - use the same transformer for protection circuit and fan. Set it up ct, use a bridge for +/- and a single 1n4007 followed by a small cap for the fan supply. You can make very simple fan speed control with a pot and a mosfet. You can add an extra cap across the resistor to help starting if slow speed operation becomes a problem. All fits on a small piece of perfboard. Layout not critical.
Papa posted a circuit for this many years ago, I will try to redraw it when I get home, but will try to describe it;
1N4007 and 100 uf (value not critical) cap create a ~9V supply from a 15VAC winding and ground.
10K pot connects across the 9V and ground. Can be single turn, 10 turn or 25 turn if you really like turning things.
To +9V connect the fan +
To fan - connect the drain of an n channel mosfet. General purpose anything like IRF610, IRF510, etc. (to name what's in my parts bin)
Source of mosfet to ground.
Wiper of pot to gate of mosfet.
1-10 uf from mosfet gate to V+ if needed to help startup.
The voltage at the mosfet gate controls current, which is controlled by the voltage divider created by the pot. The cap from V+ to gate creates a spike on turn on that will give the fan plenty of juice to start and then drop down to a lower running speed.
Old 20th January 2014, 09:22 PM   #29
Thanks a lot BobEllis, I think I will learn a lot with this project and everybody advises (even if some of them are still little obscure form me right now)
I'm eagerly waiting for your drawing, but I will try to understand the concept from your description.
Old 20th January 2014, 09:29 PM   #30
Zen Mod's Avatar
oomph
Beginner's Build Guide: Pearl II jhsjhs99 Pass Labs 96 17th June 2013 05:20 PM
Beginner wanting to build a subwoofer amp mk2singh Class D 8 28th October 2012 04:19 AM
First Amp Build, (But not complete beginner to electronics) agreco1489 Tubes / Valves 12 2nd July 2012 06:26 AM
Planning an F5 build - some beginner questions njepitt Pass Labs 144 15th March 2009 11:55 PM
Beginner looking to build Bloody_Sorcerer Subwoofers 5 27th October 2007 08:56 PM
Copyright ©1999-2017 diyAudio
