LSK pre - BAF 2013
LSK pre - BAF 2013
Old 14th October 2013, 10:00 PM   #21
flg is offline flg  United States
flg's Avatar
I just figured that with Idss of 10ma on the JFETs you get 20ma through the 1k and 25Vds on the JFETs. You might have to loose 2-3Vds through the cascade JFETs so you might get 22Vout. No other changes, the simple way...
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 15th October 2013, 05:02 AM   #22
6L6 is offline 6L6  United States
6L6's Avatar
LSK pre - BAF 2013
Ooooh!
Neato!
:subscribed:
Old 15th October 2013, 11:17 AM   #23
flg's Avatar
Well, I was somewhat mistaken above regarding "no other changes". You will need to adjust the Resistors driving the gate of the cascode transistors for a slightly higher voltage. Where N.P. has 18V you will need about 5 more Volts there. You can get that by lowering the Rs on each rail or raising the Rs in the middle. I don't have a pic of the schez or I'd give the ref des for the Rs. It should be simple to calculate and get close.
Old 15th October 2013, 11:21 AM   #24
buzzforb is offline buzzforb  United States
buzzforb's Avatar
A balanced version with cascaded FE feeding folded output is done using smd parts. Don't know how popular the balanced or smd would be for general use.
...Shape the sound , Man!
Old 15th October 2013, 12:46 PM   #25
juma is offline juma  Germany
juma's Avatar
Originally Posted by flg View Post
...You will need to adjust the Resistors driving the gate of the cascode transistors...
Exactly - current supply resistors need changing in that case too. With changes shown in the sch. below I got about 28V_peak of clean swing at the output (I didn't dare to go higher since the J74's Vds reached 29V). The current through R2/R11 (1K) was 16 mA (about 6mA through JFETs and 10mA through BJTs).
Old 15th October 2013, 04:23 PM   #26
flg's Avatar
So Juma, what do you think of BJTs in the cascode position?. They are generally regarded, even by N.P. typically, as the better solution here. But, he chose to use more JFETs in this design?
Thx
Old 15th October 2013, 05:46 PM   #27
massimo is offline massimo  Italy
Juma, is BC547C for Q2 a typo? Did you mean BC550C ?
Old 15th October 2013, 05:49 PM   #28
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
LSK pre - BAF 2013
Keep in mind that this was an exercise in using LS parts exclusively.
Old 15th October 2013, 05:57 PM   #29
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
LSK pre - BAF 2013
...so there are better choices ? like Juma's ?
Old 15th October 2013, 06:44 PM   #30
I dare say we should read between the lines.....
Or thruogh the emoticons
LSK pre - BAF 2013Hide this!Advertise here!
Pass at BAF 2012 Nelson Pass Pass Labs 37 27th July 2015 11:40 PM
BAF-Streaming video technicalities ashok Clubs & Events 0 10th April 2012 05:07 AM
The Pass room at BAF 2011 Nelson Pass Pass Labs 2 7th September 2011 03:33 AM
What and Where is BAF? Troncones Tubes / Valves 10 16th January 2011 02:30 AM
Baf stuffing > trouble? ALFIrE Multi-Way 2 24th November 2004 10:20 AM
