Well, I was somewhat mistaken above regarding "no other changes". You will need to adjust the Resistors driving the gate of the cascode transistors for a slightly higher voltage. Where N.P. has 18V you will need about 5 more Volts there. You can get that by lowering the Rs on each rail or raising the Rs in the middle. I don't have a pic of the schez or I'd give the ref des for the Rs. It should be simple to calculate and get close.
Exactly - current supply resistors need changing in that case too. With changes shown in the sch. below I got about 28V_peak of clean swing at the output (I didn't dare to go higher since the J74's Vds reached 29V). The current through R2/R11 (1K) was 16 mA (about 6mA through JFETs and 10mA through BJTs)....You will need to adjust the Resistors driving the gate of the cascode transistors...
But, he chose to use more JFETs in this design?
Keep in mind that this was an exercise in using LS parts exclusively.
I dare say we should read between the lines........so there are better choices ? like Juma's ?
Or thruogh the emoticons
I think they are the right tool for the job...So Juma, what do you think of BJTs in the cascode position?. ...
Yes, but they are so similar that it shouldn't be considered a mistake in this case.Juma, is BC547C for Q2 a typo? Did you mean BC550C ?
OK A little marketing...
Thing is, I have BC550 etc, and Toshiba Js & Ks but, I don't have LS Js and Ks
Are there complementary SITs of like power to the JFETs used in the shown schematics?If you have the Toshibas you are good. The LS is just a replacement Toshiba.
Antoinel, check this pdf http://www.circuitdiy.org/Datasheets/SKU17-1.pdf
Small signal devices don't have complementary, but K69/J19
Thank you massimo. This SIT pair will broaden the use scope of the circuit presented by Mr. Pass at BAF 2013. A complementary folded cascode SITs may have a lower Zo than that of analogous JFETs, and thus save an additional output buffer if it is low enough.Antoinel, check this pdf http://www.circuitdiy.org/Datasheets/SKU17-1.pdf
Feedback from the output of the Pass circuit to the gates of its FE may fit the practice of Schade or Pass feedback. Consequences are a lower voltage gain, but with a new triode-like characteristics if desired.
Do you need resistors on the bases of the BJTs for stability, or is that not a problem in this circuit?
what are we using for a volume control???
I asked Nelson at BAF and he suggested a pot on the output.
Thanks to a nice person in Japan I have a few 2SK78B and 2SJ78B, SIT
complements, a couple hundred volts Vds, 0.5 amp and higher power.
Unfortunately, I do not know how to obtain more, otherwise they would be
sitting in a DIY project right now.
- LSK pre - BAF 2013
