Old 14th August 2012, 06:00 PM   #771
lhquam is offline lhquam  United States
Originally Posted by Zen Mod View Post
what you mean with parasitic currents ?
loading of secondary is of most importance here
Referring back to post 742 F6 Amplifier, is there any problem using method B if an appropriate load resistor is placed across the secondary? As discussed earlier, method B might suffer more from xformer parasitic currents, but has fewer capacitors involved.
Old 14th August 2012, 06:34 PM   #772
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
looking at pic from #742 (attached )
in case B AC path for modulation is through C4 , which serve also as bias voltage blocking/maintaining/smoothing cap
in case A AC path for modulation is through C1 ; in that case C3 is just bias voltage blocking/maintaining/smoothing cap
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 14th August 2012, 08:11 PM   #773
Can C4 serve both duties as well as C1/C3 in method A?
Old 14th August 2012, 08:39 PM   #774
Default Secondary loading alternatives
In the following drawing, methods B1, A1, and A2 show some alternatives for loading secondary winding and biasing the output FET. In all cases, Rsec is the secondary load resistance.
Old 14th August 2012, 09:02 PM   #775
Zen Mod's Avatar
it is not an issue
fact is that in both cases we are having one cap in series with secondary
and in case A it's possible to have adequate loading of secondary
Old 14th August 2012, 09:06 PM   #776
Zen Mod's Avatar
if you ask me - any of A derivatives
which one suits you most ......
Old 14th August 2012, 10:38 PM   #777
Rush is offline Rush  United States
I don't like caps in the signal path. They make me want to buy $100 each or more caps and worry why I was too cheap to buy Audionote $1000 silver foil caps. So my 1st preference is "B".
Then it occurred to me that sometimes we do things that make the output device exhale the smoke within. Does this trick of letting the smoke out ever short the gate to a rail and possibly burn out a winding on the secondary?
That would be bad, making me reconsider "A". But I don't know the likely hood of that. I have not let the smoke out yet.
Rush
Old 14th August 2012, 10:47 PM   #778
Zen Mod's Avatar
I told ya - in B you have cap in AC path , too
think about impedances
Old 14th August 2012, 10:58 PM   #779
Yes, but, the cap is on the non-signal side of the winding where the AC goes to ground (or rail) with a lot of impedance between, so I think the cap is less critical than halving the full signal coupling through a cap.
I could be wrong, but that is what I think right now,
Rush
Old 14th August 2012, 11:41 PM   #780
Zen Mod's Avatar
there is no non-signal side
even in case of B1 case (post #774) , where you have proper loading resistor across secondary , value of C2 must be sized accordingly to wiper-lower end section of trimpot , calculated as bypass cap , or it will not serve prescribed duty
in that case - it's AC impedance is low , so trimpot value is of no importance , AC wise
conclusion - cap is in AC signal path ...... as it must be , because Jfet likes to see signal between S and G
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 25.00%)
Copyright ©1999-2013 diyAudio
