#231 |
yes I understand your intention Mike....
my deviations are more due to the lack of the bulbs but .... I ordered already three 3,3 Ohm (50W) and three 1 Ohm resistors (50W) so I will build up a chain and "dial in" for the sweet point.... I also ordered the halogen sticks ZM recommended.... ![]() So in some days I will have the published version .......and will take it as basis.
and the First W tt is......a really First Class P SS Idea !
#233 |
hi tea-bag,
that is really very nice and if the resitors do not work or do not have the magic (what do you think Mike) I will return to your offer .... ![]() ![]() ![]() ![]()
#234 |
Hello all !
![]() I am reporting some values from my amps build : I am pushing right now at 2 amps of current , which is obtainable - in my set up - with a 1500 halogen bulb ( 220 volt ) . So at 16volt of Vds ( without degeneration example ) the halogen sticks offer about 13 ohm of load @ 42 volt of Vdd . My couple of 2ks82 KD33 I have are a different match : -5,16 Vgs and -6,5 Vgs . I have ordered one more couple and hope to have a better match , even if I do not feel audible differences between the channels . Now , at 2 amps the heat sinks run pretty hot ( with grease applied ) , so I will not take them that way for a long time , unless I find some bigger hardware in the next days . Interesting is , that like in the DeLite amp - with my "6 ohm" speakers I "tend " to prefer a load around 15 or 16 ohm , which in that case of the Dmosfet the result of the bottom end of the music was a little more boomy but in a good way . Interesting -just , that the boomy effect is gone comletely listening to the Sits , so I think I will try the same configuration with a 16 ohm load ( around 1300 watt halogen bulbs ) and raise the current trough an higher VDD . We'll see .... and listen . Soon back to 20 ohm and less dissipation .
#235 |
By the way they sound very good @ 2 amps . Wonderful amp .
#236 | |
www.audiohobby.com
Resistors are fine (probably ever so slightly better). They're just not as glowy.
My Website, Projects, Sale Items |
#237 |
oh,
I found some information about the meaning of KD-33 I think in an old manual of the Sony TA-N88 the marking seems to be the pinch off voltage (?) and the fluctuation of one Vp rank is acceptable, could been KD-33 and KE-33 is in a comparable range. also interesting to know when I first measured the S-D resistance I was shocked by the low resistance and thought I had shot one, but look at the text, S-D is normally 1-3 Ohm and S_G and D-G should be diode characteristic........ ![]()
#238 |
and for this .... for me and other people that do not know....
a similar problem was discussed here.. Sony TA-N7B VFET Help!! The problem with these parts, apart form the price, was the very fact they were depletion mode, with Vp of about 25V for the J18/K60, and a whopping 55V on the J28/K82. Hi-Voltage JFET's
#239 | |
Because the halogen bulb will not reach the needed operating temperature (>240 degree celsius on the bulb) to recycle the vaporized tungsten back to the filament. Resulting possibly in a black bulb and shorter lifetime than expected. Franz |
#240 |
www.audiohobby.com
Looking at Stefano's numbers and Gerd's Vp info. It looks like the grades may represent a fairly wide range of Vp, which relates to Vgs.
This isn't a big deal for Figure 10. And your devices needn't be Vgs matched precisely from channel to channel. But, if you build Figure 11, and your KD-33's Id is more than 2.4-2.7A, you'll probably want to start building a separate bias supply and move on to Figure 10. I got a couple of KE-33 and they biased-up at around -8V in Figure 10.
My Website, Projects, Sale Items Last edited by Michael Rothacher; 9th January 2012 at 12:08 PM. |
| L’Amp: A Simple SIT Amp: Part 1 | Michael Rothacher | diyAudio.com Articles | 20 | 2nd March 2013 08:26 PM |
| SIT Amp Article Out Now | Variac | Site Announcements | 0 | 2nd December 2011 07:55 AM |
| Srajan has the 1st SIT amp for Une dégustation | vizion | Pass Labs | 131 | 14th November 2011 11:41 PM |
| SIT-Preamp | VladimirK | Solid State | 36 | 27th August 2011 08:36 PM |
| New SIT - old problem | StevenOH | Parts | 2 | 13th June 2008 10:46 AM |
