Old 6th October 2011, 01:52 PM   #1
Default JLH/PLH PC Boards?
Does anyone know if a PCB board was made for the PLH amp?
Ta
WM
Old 6th October 2011, 05:39 PM   #2
The one and only
Nelson Pass's Avatar
I did not make one, but I probably could.
What dimensions? Are you mounting outputs on the board?
What are the hole placements?
Old 6th October 2011, 06:14 PM   #3
Hello Nelson,
I would want to mount the outputs on the board - well on the edge of the board I guess?
Mono boards and I was hoping to use the IRFP240's that I have assuming they can do the duty.
Dimensions are not critical would design the box around them...
I really dont know how you find the time to be so active in this forum and produce all the kit you do as well!
Much obliged.
WM
Old 6th October 2011, 06:26 PM   #4
I would totally buy a PLH board.
Old 6th October 2011, 06:47 PM   #5
Yes I am sure the list here will grow!
Nelson one other thing I have just thought of - I would want the version with paralleled output devices i.e Fig 11 in your writeup?
Thanks again.
WM
Old 9th October 2011, 03:03 PM   #6
O.K not growing... :-)
Never mind Nelson clearly not worth it!
I will look at recreating JLHs bipolar endeavours instead.
WM
Old 9th October 2011, 03:28 PM   #7
knutn is offline knutn  Norway
I am working on an all-FET version of the JLH class A, where the ouput is very similar to (OK, nearly a copy of..) the PLH amplifier. So it is a 4 transistor design. But I use split supply (plus/minus 24 V).
Old 10th October 2011, 11:16 AM   #8
Hello,
Thanks yes I would be interested - I need the PCB foil pattern though which is why I have switched to the JLH bipolar 1969 version - I have got a foil pattern for that.
Ta
WM
Old 10th October 2011, 06:09 PM   #9
Here is the schematic. I have ordered the PCBs, and as soon I receive them, I can start mounting the components before initial testing.
I plan to use a 2x18 V 500VA transformer common for the two channels. I also have two quite large heatsinks (0.3 K/W) which I plan to use. This amplifier favours high quiescent current, so maybe I can set this as high as 1.8 A...
Old 10th October 2011, 06:30 PM   #10
The one and only
You are perhaps missing the opportunity to adjust the balance between
the positive and negative output drives. Look at the pots on the PLH
schematic.
making pc boards trespasser_guy Construction Tips 157 7th February 2012 01:00 AM
J-JLH or PLH-J ? drjbf1 Pass Labs 11 28th July 2011 01:37 PM
PC Boards for v9? LizardBrain Group Buys 334 20th July 2008 11:59 PM
PC Boards PrimaLuna Parts 3 18th March 2006 08:26 AM
JLH boards MikeW Solid State 1 8th July 2004 07:07 PM
Page generated in 0.70200 seconds (15.44% PHP - 84.56% MySQL) with 11 queries
