F5X -- the EUVL Approach
Old 28th December 2011, 04:10 AM   #621
EUVL is offline EUVL  Europe
Dave Smith said a year or so ago that leaving it out makes a big improvement.
I have not tried, as my boards are now with Mark.
I think Uwe left them out.
So depends on how experienced you are and how much risk you want to take.
It is well know that I like shorting my outputs with relays to protect the speaker.
Relay is then not in signal path.
So some current limit is useful to save the FETs.
Bear in mind the Toshiba's are becoming rare commodity.
So you should have at least a few sets in reserve.
Patrick
xen-audio.com
Old 28th December 2011, 04:27 AM   #622
Nikon1975 is offline Nikon1975  Austria
I left it out when I replaced the IRF boards with the Toshiba board. Did not do any A/B comparison, and managed not to destroy anything...until now.
My son shorted the output out the F5 with limiter, and anly the fuse blowed. Now the cable are screwed so tight that you need a wrench to unplug them.
D.
Old 28th December 2011, 10:48 AM   #623
audiok is offline audiok  Hong Kong
audiok's Avatar
Hi Dave,
Thanks your sharing. I will try to build your F5X version on 2012.But can you tell me the difference between "Ground x" and "Floating X" .
Br,
Tsang
Old 28th December 2011, 03:47 PM   #624
In the grounded x, the amp is basically two separate SE F5's driving the same speaker with out of phase signals. If you only feed a SE signal to Vin+, and 0V to Vin-, one side of the amp will be idle.
By floating the X, bit sides of the amp would be operating even in the case of a sE signal, though we still recommend you strongly to use balanced signals as input.
Patrick
xen-audio.com
Old 28th December 2011, 03:56 PM   #625
fitzfish is offline fitzfish  United States
Originally Posted by EUVL View Post
Many thanks for posting, for the hard work over the past year despite private circumstances,
and all the testing and excellent results that is to come in the Build thread.
My pleasure Patrick. It's been a lot of fun to get to where we are.
Originally Posted by audiok View Post
...can you tell me the difference between ground x" and "Floating X" .
Hi Tsang,
Yes, no problem.
Grounded X is essential for biasing the amplifier after construction and is also useful if you want to use each board for two separate channels. In grounded X configuration the two halves of the circuit (left and right side in the schematic posted) are essentially two separate amplifiers on one board that are configurable as a single channel in bridged mono mode or as two seperate channels. Applications like multi-channel or bi-amp come to mind...
Floating X configuration connects the left and right halves to each other in the complementary configuration so that the amplifier becomes a true fully balanced amplifier from input to output. This allows the amplifier to accept either balanced inputs or single ended, RCA type inputs.
There will be more information on this in the build thread coming soon.
Dave
Old 28th December 2011, 03:57 PM   #626
Hi Patrick,
Typing at the same time it would appear!
Dave
Old 28th December 2011, 04:03 PM   #627
There are some good reasons to use grounded X.
For example as Dave has said :
If you want to use the amp as SE, and you have a two way speaker with active crossover, you can run each balanced PCB as 2 power amps for one channel.
All you have to do is ground the X, raise voltages to +/-24V, change bias to 1.3A per FET, and you are in business.
Patrick
xen-audio.com
Old 28th December 2011, 10:56 PM   #628
TheShaman is offline TheShaman  Europe
Great job guys.
I hope you take it to the next level with F5X-T..
It's going to be fun shipping *those* heatsinks around the globe..
Old 29th December 2011, 07:54 AM   #629
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
...which in turn, by means of adding a third output binding post tied to ground, allow you to use it as a 4 channel amp, for example for bi-amping purposes. Great flexibility!
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 29th December 2011, 08:25 AM   #630
qusp is offline qusp  Australia
qusp's Avatar
thanks for the final schematics guys, btw that regulator pdf is massive!!
F5X -- the EUVL ApproachHide this!Advertise here!
